so if i turn them around will their be less bass.....or about the same?
i read this
"Mounting the sub inverted actually helps SQ depending on the sub. For example, if you have an Infinity Kappa Perfect VQ, it's got a humongous magnet, no way that magnet will fit inside a sealed box with the minimum internal volume (0.3 cu ft). So you put the motor outside the box.
Second, this actually "creates" more box volume (when you're too lazy to build a new box) because hte motor structure isnt taking up space in the box anymore. This depends on the box size. 0.1 cu ft of sub rear end won't matter in a 1.5cu ft box, but it will be bigger in a 0.7cu ft box.
Some say the bass gets deeper when mounted this way, and attribute it to the volume "gain". Personally, though, I think its because of better power transmission. now the wires go straight from amp to sub, no need for those $2 connectors that used to be in the box."
