Im not sure both front and rear are maxed out but the rear does have too muchnicely done what degree is your camber?
Either run a lower offset, slimmer wheels, or more negative camber. You just have the wheel poking out outside the fender. You want it to be flush; at least the top part anyway. That's just my opinion though. I'm not a huge fan of the "hellaflush", "down and out" or "low and poked" scene.I got a blackworks front camber kit and its maxed out.. If i go any lower i will rub tire when i turn. How can i fix the "awkward poke" lol?
yeah they're 195Either run a lower offset, slimmer wheels, or more negative camber. You just have the wheel poking out outside the fender. You want it to be flush; at least the top part anyway. That's just my opinion though. I'm not a huge fan of the "hellaflush", "down and out" or "low and poked" scene.
What size sidewall are you running? That would be a big part of why your wheels are rubbing.
No no hun, your sidewall? The 195 is the width.yeah they're 195
195/50/15 i used the same tires for these wheels
uh yeah im dumb... Well ill need new tires soon anyways but until then im running the "awkward poke" hahaNo no hun, your sidewall? The 195 is the width.
Lookin' good!Drove up to Oklahoma for CCM 13 and had to use 4 quarts of oil in 3 days which is not good.... I'm getting it checked out today. There's no leaks, its not burning and i haven't hit v-tec in over a month so im having the dealership we bought it from check it out for free today but here are some pic from the meet
My friends 03 RSX type S <3
I usually have to put a quart in mine every time I fill up the tank...that's pretty much once a weekvtec can burn oil like nothing else you have seen. Not vtec itself obviously, but any high mileage vtec engine I have seen does this.
