I my shift knob from a local store here. You should be able to find one on ebay. Or look around on some car parts sites. All I did was unscrew the two screws holding the stock shifter, take it out and put the shifter on with a little force (if you don't put it down a little, it won't shift because the button won't press the thing to shift, or if you put it all the way down, you'll alwasy be in gear) The shift knob came with three alen screws. And the shifter has pre drilled holes. From there I just screwed those in to hold the shifter. unfortunately, the shifter does get loose from time to time. Just have to take out that metal part, cut it to make it shorter..(too high) and drill holes for the screws..CivicSean94 said:d16,
Hey how did you get your shiftknob on and where did you get it from? I bought one just like it last summer and it didn't fit.Then the stock one broke so I've been driving around without a shiftknob for the last 9 months.By the way the car looks sweet.
Thanks. Yup it was purple...RacerAce6 said:looks nice i like the reverse glow gauges!!! did ur car used to be purple?
