great job! i have a few quesions:
are these charge pipes the same?
if so, you did an amazing job finishing that pipe. Do you do metal fabrication for a living?
do you not have any flex pipe in the exhaust?
Yea those are the same pieces. All my pipes and exhaust started out as "U bends". The only part of my exhaust that was an actual straight piece was the middle piece. I didn't use a flex pipe cause the engine is already stiff with my Hasport mounts and I mounted the exhaust onto the car itself; zero movement or vibrations/rattles. Same with my intercooler pipes. No flimsy parts, so no movement what so ever. I had to cut and smooth them into that form, mocked them up, and then did the final welds. Once it was finished being welded, I just grinded the welds down where the eye can see to have that clean and smooth look. I didn't grind any hidden parts or the exhaust pipes.
I don't metal fab for a living. I just learned from reading and my cousin's father is a welder at CAT, so he gave me some pointers. I just borrowed their welder and after many tries on random metal pipes, I did my own pipes and exhaust. It didn't take that long to learn, it's about the right amount of wire feed, voltage, technique, etc. It's not the best of course since it's my very first fab job, but it does what it's meant to do and there are no leaks. So it's good for me since it's my first piping kit and exhaust.
