Mehhhhh. I'm not sure. I need something "flashy" because after all it's just a show car at the end of the day. What do you think of the password jdm block off grills?
Wouldn't the block off grill create issues with the cooling system? Then again the 5th Gen didn't have a grill and all of our cars have plates underneath that push air up to the radiator.Mehhhhh. I'm not sure. I need something "flashy" because after all it's just a show car at the end of the day. What do you think of the password jdm block off grills?
It's different and I don't believe I've seen one on a car in person before.
Sent from your moms house.
I highly doubt it will.Wouldn't the block off grill create issues with the cooling system? Then again the 5th Gen didn't have a grill and all of our cars have plates underneath that push air up to the radiator.
Thanks . Have yet to see another one in person.Looks good Bro! I also own an EG with an EK look and ours is a really rare convert. I really like how it turned out, keep it lookin good fellow EGK rider! good Job with the Car!
What do you mean? I've done a quick little read on the size. From what I've read it should fit ok, may need a little camber adjustment.are you going to make them fit under the wheel arches?
Ill read into it just to double check. My fronts are 15x8 0 and they stick out far. My rears are 15x7 +38 and they sit In a bit.a 15x8 +25 sits past the fenders....+20 would be a little further out. I would imagine you'd want to use them without a ton of camber, or i could be wrong.
you're going from a 15x8 +0 front to a front wheel that is not even an inch closer to the body. So if your current fronts sit more than 1 inch away from the fender, then the new wheel will still sit past the fender as well. Your rears sit inside because it's an inch skinnier and also an inch and a half higher offset which is putting the wheel even further inwards toward the body.Ill read into it just to double check. My fronts are 15x8 0 and they stick out far. My rears are 15x7 +38 and they sit In a bit.
