if i make the pics an attatchment, they'll turn out pretty big... just let me get a pic of me and eric together, and then i'll send them to yaAEM EJ1tuner said:Bigger pics... You guys need a "couple's sig." C'mon, I'll make it for ya... just get me the pics!
gabebauman said:Here's a little something to spice up your front too. http://www.clubcivic.com/board/showthread.php?t=25166
not hard at all....just take your time and don't overtorque the bolts.....also a good investment would be a hondata IM gasket......they do work ..the design cools the air a little more before entering the head....the biggest headache was the throttle body......if you are going to use the stock gsr throttle body..don't use a gasket between the mani and body..it will cause a vaccum leak..instead buy a tube of hightemp gasket maker stuff.....and use alot around the throttle body....and test for leaks...another thing to do is clean the idle air control vavle while you have it out....it sits on the back of th im.....but other then that simple job !96 DX Hatch said:looks nice, bet it flys too
and how hard and how long does it take to install the skunk2?
got mine yesterday for my gsr and next weekend = install when i get my v2 & dc header
check your PM5thJennDelSol said:if i make the pics an attatchment, they'll turn out pretty big... just let me get a pic of me and eric together, and then i'll send them to ya
thanks for info. ordered my v2 & 4-1 last night, 4.5" and hi-flow are today, cant wait to see/feel difference when i install everythingHS-POKEY said:not hard at all....just take your time and don't overtorque the bolts.....also a good investment would be a hondata IM gasket......they do work ..the design cools the air a little more before entering the head....the biggest headache was the throttle body......if you are going to use the stock gsr throttle body..don't use a gasket between the mani and body..it will cause a vaccum leak..instead buy a tube of hightemp gasket maker stuff.....and use alot around the throttle body....and test for leaks...another thing to do is clean the idle air control vavle while you have it out....it sits on the back of th im.....but other then that simple job !
very much agreed....lookin at getting a teg type R header/mani soon...gotta have the flow when i put those pistons in...lolanekin007 said:very nice...it needs a header though..the stock iron cast header looks ugly...
