NA d16z6 sohc vtec
civic95
CarbonCreations said:
greddy will be no where near that power. youll be lucky to see 190+ whp with the full greddy kit (kit+ IC kit).
turbo is the way to go. ive made SO many posts about how to piece together a strong cheap turbo kit... let me find one and ill brb
Could you be so kind as to send me one of those pages if you can find it?
smitty82pu
"hail hail to old Purdue"
oh he can get that much out of his d.. big ass bottle.. lol.. i would go with a turbo too and the greddy kit is a little mild but if you were just going for a daily driver to work that is the way to go.. you can pull that 200 out of your d N/A im sure but the drivability would suck i bet.. im sure there is someone on here that will at least claim they have done it so give the thread some time or do a search for one if you havent already.. good luck!
Beelzebubba
SubGenius Member
Well I've seen a z6 @ 12 psi with a STOCK block make 262whp and 217wtq with probably one of the smoothes power bands Ive ever seen for a turbo.
That's cool and all but I meant Naturally Aspirated, on pump gas, no nitrous. Without some serious custom port work I doubt you'd see much over 150 whp.
92bxcivicman
Dude get the head ported and add some stage 2 skunk 2 cams and cam gears. remove the stock intake resognator( in the Wheel well) add a stock style k&n Filter. then add a dc header and pacesetter cat converter. then add a b&m fuel pressure regulator(up the pressure) and add a v-tec/air fuel controler and add a p28 ecu.Get it all dyno tuned and you should be close. just trying to help money with a budget buildup and dont need anyones 2 sense. thanks for your time holla back doggy. oh also fill up on 94 ultra and a bottle of nos octane booster.
Martin Racing Design
FKA Carbon Creations
not even dude. not even close. going from 105ish to 200 whp takes way more work than that.
http://www.clubcivic.com/board/showthread.php?t=12746
buzzbombtom
captin sleep0
hahaha you know you are talin aboutr my car right, that is everything i have and the power isnt what you think i have more too.
0k that confuzes me.. so do you have more or less power with more or less parts?
buzzbombtom
captin sleep0
ok i got those parts but some more look at the tac steeting thread, it has all my mods and i have enough power to kill any sohc but i want to beat/keep up with dohc so it isnt fast enough for me. i have a lot of power just not enough for me
slammed_93_hatc
NoR*CaL knowledge b***h
holly s**t, if you think that will get him any wear NEAR 200whp then you must be smokeing some CRAZY ass s**t.
first off i never want to here you say "dc header, pacesetter" in the build up plane for a serious motor.
if this stament was ment to be sarcastic then forgive me i couldn't see any there
tigasnatigas
ok guys what do u guys think i will get with all those boltons,i bought all these things from a friend aem cai $28 exhaust whole pipe$100 camshaft59300skunk2 $220 aem camgear$30 skunk2 intake manifold$200 crank pulley$50,act clutch w/lightened flywheel$240 used msd igntion 6al $75 so will this be near 200 whp or what...if not what else can i do .
smitty82pu
hmm.. i would say you should be around 150whp or maybe a little more now.. you have to remember regardless of what some people say on here that stuff is only going to add a few hp here and there, nothing on that list adding more than 6-8 hp each.. a few will disagree im sure but go dyno it and find out yourself.. remember the 125 hp your z6 has stock is only more like 105-110 whp.. like many have said on here you wont hit 200 unless you do internal work.. you just cant jump 95% in whp with simple bolt-ons unless you go FI.. if you stay NA you will have to get major head work and bottom end work both to get anywhere close i would think.. you could spray it and hit that though, which i dont recommend unless you are gonna do the motor soon anyhow..
your still not going to see 200 whp on a d-series unless its not street legal.
Spencey
for the money you're going to be dumping into that motor to do this to make a car that isn't street legal if you are going for 200whp, its going to be a lot easier and cheaper to just boost the thing, thats what I'm working on doing
buzzbombtom
captin sleep0
k, you will not have that much horse i have so much more than you into my car and it sucks ass not fast as you think, i rode in an ls turbo last night and i will baller down get rid of vtec and do ls turbo, it was so fast in the 13s so fast
swap would be cheaper and more power. hell i/h/e/cams is almost a b16
buzzbombtom
captin sleep0
i dont know about that....... but getting a turbo on your car will put you into the 13 sec range no street car sohc cam na will give you power like that
tigasnatigas
so for $1000 i can go FI is that what u guys are saying and by going FI is it reliable, how long will my car last until it breaks down u think, than goin NA, so whats more reliable, going NA or FI.
buzzbombtom
captin sleep0
you can get a greddy kit for like 1600, no intercooler. niether is more reliable, boost needs the engin to become upgraded to handle it but na motors wont smog in most places
