What do I need to put in my car to make it so the sound is clearer when the volume is higher? Right now I just have the stock speakers and a panasonic CD player. Any higher than volume 22(not very loud) and the sound gets distorted. Thanks guys
just the opposite, I just don't beleive in the rear fill theory.qwikxr said:so snoopy isn't into imaging LOL
Ahhhhqwikxr said:No trying to start a battle battle.. Just trying to head of misinformation..
Go to a concert.. the band sits in front of you, not behind you. The music that you hear from behind you is a lighter volume, due to the fact that it is reflection from the rear of the auditorium.
RTA (Real Time Analyzer) a system where the rear speakers are as loud as the front, and you'll score a low number, as there is no "presence" or "sense of direction" as to where the band is placed.
If you care nothing of quality, then have at it - amp them all the same level. If you care for quality and imaging, then set the system up correctly.. Take it a step further, and introduce a center channel to the system, and do it at a very low volume, or a much higher impedence, like 8 or 16ohms.. This will naturally drop the volume level..
Sit in two identical cars, with the exact same audio equipment.. One set up your way, with the 4 midrange drivers all receiving 50W, and say a 10" sub on 100W. The other car with 50W on the front stage, 20-25W on the rear (or less), and a 10" sub with 100W. See which sounds much more realistic, and more clear. I'll bet you a dollar and a dozen donut holes that the correclty staged system will sound much better, and will also score higher on an RTA.
It all boils down to personal preference, and ultimate goal.. If you just want a loud system, then your way works. If you want a quality, properly imaged audio system, then do it the right way.
I did car audio installation for years, and am MECP 1st Class certified installer, not that that makes a hill of beans to most, but it does mean that I know what I'm talking about.
Cheers and beers
