Next Engine Mod Before Turbo?
edhgreatone
I was wondering what my next engine mod should be before i do my greddy setup. I do not plan on doing the interals because i am only running 6-8 psi. I am putting on greddy evo exhaust. I was thinking about skunk 2 intake manifold but i heard that with the greddy emanage system it will screw things up because this system is made for a stock engine not a modded one... should i just start saving for the turbo or is there aynthing else i need to do to prepare for this setup.... thanks
lanojp1
new clutch?
$lick Rick
TEOTWAWKI
gauges, cant have too many gauges with a turbo, turbo timer, upgraded parts from the base turbo kit.. etc
edhgreatone
yeah def. on the clutch and the gauges... can you guys give me sites on where to find the gauges and i'm looking for a clutch/flywheel combo but i don't want the flywheel too light so if you got any good sites for them please post thanks for help
edhgreatone
would this be a good clutch for my turbo:
This is an ACT cltuch
Heavy Duty Pressure Plate w/ Street Disc Kit
also with the flywheel you get to chose either 11.9 or 8.4 which would be better for turbo setup.....?
$lick Rick
TEOTWAWKI
the 8.4.
with a super high hp turbo setup, too light of a flywheel can break. but you wont have to worry about that one little bit with a civic.
Handlebars
None Taken.
keep the stock fly, either get it resurfaced or just get a new stock one. you wont want or need a lightened one with boost, the engine is gonna rev quite a bit faster.
SeanMc300
professional a*****e
im gonnna get a organic clutch, you wont need a hardcore race/street one with just a greddy kit. if i were you id get a turbo timer, guages, clutch, high flow cat, boost controller, and oh yeah, a hondata.
baby99si
N/A project has begun....
No manifold? So with my Ported ITR manifold is the blue box going to get f**ked up because it wont be on a stock engine? i didnt think that would make a differance because ITR manifold is still an OEM manifold but i also have ITR cams soon to be GSR cams in to, so if i dont get a hondata to replace the blue box will i have detonation? And what other problems?
Handlebars
None Taken.
holy crap... you dont use the stock manifold with a turbo, you need a turbo specific one. wow.
baby99si
I didnt get waht you just said there are turbo specific intake manifolds? Well i know there is but i didnt know you have to use a certain intake manifold for a turbo.
EDIT: i am not talking about the exhuast manifold if that is waht you are thinking, but right now you confused the s**t out of me with what you said.
baby99si
So are you going to let me know what you were talking about or what?
Handlebars
None Taken.
i thought u were talkin about exhaust manni. but yes there are turbo specific intake manifolds.
baby99si
But to the question, since i have cams and differant manifold that means i cant use the blue box and HAVE to get a hondata?
Handlebars
None Taken.
you dont have to, but its a really, really good idea. having a modded motor will take the greddy outside of its very very narrow design perameteres- a completely stock motor- so you may risk leaning out and detonating it. how much risk is anyones guess.
edhgreatone
centerforce clutch good/bad i've heard good stuff about it on clubsi.com but i was just wondering if it could hold a turbo power
lanojp1
as far as the clutch goes, get one capable of holding 100% more power than stock, i recommend ACT clutches with a street disc and xtreme pressure plate, thats what i will be using on my turbo setup..
baby99si
Thanks handle.
edhgreatone
it is a 90% increase would that be enough for a stock greddy turbo?
baby99si
Yes i woudl think so, the greddy turbo isnt going to give you insane power prolly not even 200 to the wheels, So just get what you can afford.
