no oil pressure
rushane
Hwsit guys, need your help, got a honda civic 160(d16y9),car has no oil pressure.I changed the oil pump bt still no luck
HeX
Authoritah, respected.
What did you perform to conclude that you needed to replace the Oil Pump?
Are you getting any Check Engine codes?
Have you inspected or replaced the Oil Pressure switch?
Have you inspected the Oil pick-up line in the oil pan?
And what does "Hwsit" mean?
rushane
rushane
Oil pump was damaged,so primed and fitted new pump, pick is clean n no blockage.I removed the oil filter, very little oil is coming through
Sorry "howsit" South African way of saying hello
HeX
Ohhhh... "How's it". I get it now.
"Que vola, acere!" Back at ya. Thats a typical raunchy Cuban greeting. Ha!
Anyways, have you tested the oil pump to make sure its all conbected properly and trying to pump? Perhaps theres a related relay or fuse that needs replacing.
rushane
Yeah, tested on the floor, primed it by hand and it worked perfectly, bt wen i put it on the car, no oil pressure. No electronics fr the oil pressure
HeX
Check the relays & fuses then.
xxBLOOD88SHOTxx
Surge Master
Rushane did you mechanically check the oil pressure when you tried running the car?
What exactly did you do when you started the car back up? You primed it first I assume?
