Noob turbo question
Fawks
Applesauce b***h!
Cool, so then I just lean it out until I am happy with the air/fuel and then advance the timing as far as I can without it knocking?
io_303
NIFOC
yep, if you get one of his packages it comes with a wideband to help out
Fawks
Applesauce b***h!
Also, would a T3 with 42 A/R Compressor Housing / .48 A/R Turbine Housing w/ Internal Wastegate be OK?
io_303
NIFOC
its a d16 right, then that will be fine....did you pull that of a volvo or saab?
Evan.
iTrader EVERYthing
Fawks said:
So you are saying that I can send this xenocron.com my ecu and they will chip it and put a good setup on it? Or will I be responsible for tuning the thing.
Yes, you can send xenocron your ecu and he'll chip it with turboedit, which would give the ABILITY to tune it, but then you'd have to tune it yourself. Heres the run down of how it works..
Hook a wideband 02 sensor up to your car and air/fuel gauge, read the output you get with your car being boosted.
Datalog the session (either dyno or street tune). Then pop the chip out of your ecu, use a chip burner to burn new settings, replace the chip, repeat, until your at perfect settings.
So, heres a scenario. You start your car after your kit is all hooked up, then you look at your a/f gauge (hooked up to the wideband) and see your running rich. Then you run your car and "datalog" or record the settings, then in this case, youd lower the fuel mixture since your rich, remove the ecu chip, burn new settings to it, then replace the chip, until your exactly where you want to be.
So then your probably wondering how do I get to that point? When you send your ecu to xenocron, he'd probably supply you with a basemap (a general idea of what your car settings should be at with boost). Of course basemaps are on the conservative side, meaning youd be running rich, so then youd do the above steps until you get it down to where it should be at.
Finally heres the steps to getting a complete engine management setup in your case:
1) send ecu to xenocron and get it chipped with turboedit
2) buy a wideband o2 sensor, a/f gauge and chip burner
3) do the above steps
4) have fun
Fawks
Applesauce b***h!
I don't have it yet. Why, is there an advantage with one over the other?
io_303
NIFOC
no they are the same turbo on both, but i think the Saab has an external wastegate
Fawks
Applesauce b***h!
And it is a b16.
Fawks
Applesauce b***h!
The slowest b16 evor!
io_303
NIFOC
t3 might be a touch on the small side, i would go t3/t4 for a b16
also you might have some problems with the ecu since you have a pr3 or a pw0, there is only one program that handles them well, and that is BRE you can read up on it in the pgmfi.org forum
io_303
NIFOC
its pretty but you wont see the gains you want out of the SC
Fawks
Applesauce b***h!
I wounder how many lbs it pushes.
bizoneoeh
Ex-Gang Member
you don't need a boost retard and you're paying a f**kin grip yo. I guess you want everything new, good luck ;)
Fawks
Applesauce b***h!
How do you manage you air/fuel biz?
