Help plz Code 9
So my check engine light came on after putting in a new engine. The code is a 9. I have the Honda Haynes repair manual and did exactly what it said. To check the CYP sensor, disconnect the ignition harness connector at the distributor and probe terminals D and H with an ohmmeter . And compare it to spec. Spec is 300 to 750 it read 426 so its good. Then is said to check for continuity to ground on each terminal. And that continuity should NOT exist. I checked it and there was no continuity. So it passed both the tests and then it says if it passes both the test to take it to be diagnosed at the dealer. f**k THAT 'im not about to pay over a 100 just to have it diagnosed. So i'm begging all you guys who read this to help. If you ran in to this problem before whats the fix???? I need to get the car register and have it pass smog asap. So help is needed asap lol and Thanks ahead of time. Hopefully someone know what the problem is.
