not likely its made of metal thats about 1/16" thick or a little thinner, only time i seen them break is it was bent back and forth to many times on one spotHow would a dipstick even break?
damn that sucks. you might as well just take it easy with the car for the time beingIt's raining here and turning to snow tonight. Don't have a garage so at this point I'll have to drive it like that and hope nothing happens
I actually just tried that and wasn't able to extract too much. It lowered the level about 1/4" from what I postedI've overfilled once. I used medical tubing to put down the dip stick tube and used a large syringe to extract the extra oil.
yesIf damage were to happen, wouldn't it have already since I've driven it?
Re-read what people said would happen in answer to your first question. None of that causes immediately catastrophic damage. Damage? Most likely, but not that your engine instantly quits. When the guy showed you where your dipstick was broken how would that affect how it measured?If damage were to happen, wouldn't it have already since I've driven it?
It's due to bad timing. We keep getting hit with snow here in New England and I don't have a garageI don't understand what is the big deal. Get under the car, unscrew the plug so that some oil drains out into a pan and recheck the oil level, then wipe the mess up.
