_shakademos_
My dip stick is spitting oil why is this happening how do I fix it!!!!!!!!!!
I checked that pvc not clogged it's suckingMy dip stick is spitting oil why is this happening how do I fix it!!!!!!!!!!
Yea it might be that and it's boosted 2 so even more stress u think it's better to rebuild it or swap itHigh engine mileage and worn piston rings?
These are details that should've been stated in your opening post. Is there any other pertinent info you haven't shared?...and it's boosted 2 so even more stress u think it's better to rebuild it or swap it
Unless you engine was built in the Amityville house, I believe you're referring to the head gasket leaking.I looked a little closer and it looks like the wall is leaking
