yeah traction is def gonna be a feat to overcome....i'll be sure to post the pics after getting it sleeved, next in my plans are pistons and rods then it will be getting sleeved from Benson, maybe i shoulda posted this in the FI section....if someone wants to move it, go for itCivlude said:pieces are coming along good, when you get it sleeved, please take a pic of your block before you put the head on. I would like to see it. Dont forget about traction though, it will be almost non existent when you get this sucker together and running. Slicks and axles are in your future..........
zville00SI said:Traction will be simple after I hook you up with my patented suspension setup![]()
can you literally just "spin the compressor side around"?needboost said:i seriously hope you plan on spinnin the compressor side around. it'll be nearly impossible to run a decent outlet pipe up like that then back down again. anyways, good luck dood
are you serious?h23vtecturbohatch said:can you literally just "spin the compressor side around"?
yeah, sorry i dont just take apart s**t not knowing what could happen.so yeahShiznit028 said:are you serious?
jus by the bolts on the blue part and rotating? as seen in this picShiznit028 said:yes. it literally just twists
