The pictures are either out of focus (1st pic) or too dark (others). Take pictures that clearly show whether the axle inner joint is
fully seated on the half shaft and whether the axle outer spline is
fully inserted into the hub.
If you lift the hub by hand and rotate/turn it, can you get the ball joint bolt to drop into the LCA hole?
It will also help to remove the damper fork.
