Exterior:
2000 front end conversion
Foglights
Stanely sidemarkers
type R front lip
rear lip
Spoiler
Tint windows in rear
mirror tint in moon roof
debadged emblems and holes covered up
chrome tip exhaust
99 00 rear tailights
jdm grill
driver side keyless hole door handle
Suspension:
function and form type 1
strut bars in lower rear, engine bay, and trunk
Si rims
DiY camber kit
red painted calipers
Engine:
AEM air intake
Aftermarket header
Red wire covers
Painted valve cover
Sound System:
Performance tecnique bass
Amp
Kenwood USB radio
Engine:
JDM GSR (B18C1)
Magnaflow high flow cat
Magnaflow cat back
Injen short ram
NGK wires
K&N air filter
OEM GSR valve cover
Wheels/Suspension:
16x8 XXR 521 +20
Falken 205/40/16
Koni/Gound control coilovers with front extended top hats
Blackworks front camber kit
Blackworks rear camber kit
Exterior:
Replica type R front lip
Yellow fog lights
License plate relocated
Front Honda emblem delete
Civic emblem delete
Interior:
NRG 320mm Wheel
NRG quick release
NRG short hub
VMS shift knob
Sony stereo
ENGINE:
STOCK B16A2
VALVE JOB
SHORT RAM INTAKE
VIBRANT BLACK MUFFLER
SUSPENSION/WHEELS/TIRES:
FUNCTION FORM TYPE 1
BLOX LCA (RED)
ASR REAR SUBFRAME BRACE (SILVER)
(1) SILVER ENKEI RPF1 16X7 +35 WRAPPED IN FALKEN 912S 205/40
ENKEI CENTER CAPS (INSTALLED FROM THE INNER PART OF THE HUB)
BLACK KICS LEGGDURA LUG NUTS
(2) WHITE CE28 REPLICAS 16X7 +40 WRAPPED IN FALKEN 512S 205/45
RED ANODIZED EXTENDED LUG NUTS
EXTERIOR:
DEPO BLACK HOUSING HEADLIGHTS
5000K HID KIT
YELLOW PAINTED RAYBRIG FOG LIGHTS
OEM SI LIP
P/U MUGEN STYLE LIP
INTERIOR
320MM MOMO TUNER STEERING WHEEL
NRG HUB
NRG LOCK
NRG QUICK RELEASE
2000 CIVIC CENTER CONSOLE (ARMREST DELETE)
TRUNK: REDONE FLOOR BOARD WRAPPED IN GRAY CARPET
RAZO SPHERICAL SHIFT KNOB
RAZO GRIP PEDALS
BROADWAY BLUE MIRROR
ALPINE CDE-121
2 ALPINE TYPE R 10S
SEALED SUBWOOFER ENCLOSURE
2 6.5 ALPINE SPS-610
2 6 X 9 ALPINE SPS-619
MB QUART D 1500X1 WATTS AMP
MB QUART 4 X 60 WATTS AMP
MB QUART BASS REMOTE
VIPER 5701 ALARM
-B16A SiR2 OBD1 Engine Swap, Chipped P28 ECU
-Innovative Billet Motor Mounts
-DIY Flat Black Valve Cover
-OBD2 to OBD1 Conversion Harness
-CTR Intake & Exhaust Cams
-eBay Spoon Replica 4-2-1 Headers wrapped in Black Exhaust Wrap
-S2 Catback Exhaust
-Yowai-SS Type WP Venturi Carbon Intake
-NGK Plugs and Wires
-Blackworks Aluminum Radiator
-PW:JDM Radiator Stay
-Custom wrapped Yowai-SS Aluminum Cooling Plate
-A/C Removed
-DIY Engine Bay Washers
-PW:JDM Cup Washers
-WekSoS Hood Dampeners
-S2 Billet VTEC Solenoid
-S2 Black Edition VTEC Cover
Exterior:
-DIY Black Housing Headlights
-Raptor HID Kit, 35W, H4 High / Low, 6000K
-SiR Yellow Fog Lights
-99-00 Rear Bumper
-99-00 Taillights
-EDM Big "H" Front Grille
-Mugen Replica Polyurethane Front Lip
-Hella Supertone Twin Horns
-Slick Shades Rear Window Visor
-Autozone Window Visors
-Plasti-Dipped Hood w/ Gold Metallicized Flake
-99-00 Mud Guards
-PW:JDM Red Bumper Quick Release Fasteners
Interior:
-Tenzo Type R Red Seats
-JDM EK9 CTR Red Door Panels
-Vti/SiR Gauges with CF Bezel
-Tenzo Short Shift
-PW:JDM Brass Knuckle Shift Knob
-Tenzo Hand Brake Handle
-DIY Red Gator Fabric Headliner and Panels
-Grip Royal "ROYAL KNIGHT" Black Leather Steering Wheel w/ "H" Horn Button
-2nd Steering Wheel - Grip Royal "ROYAL HINO" Red Leather Steering Wheel
-Momo Hub
-Broadview Mirror
-Single Din Tray
I.C.E.:
-Alpine Headunit relocated to the bottom
-Apple Ipod
-Alpine Amp
-Alpine Components Front
-Alpine Speakers Rear
-2-10" MTX Thunder Subs
-1000w Kenwood Amp
-500 Farad Cap
Suspension:
-Koni SP3 Adj. Shocks
-GC Coilovers
-GC Extended Top Hats Front and Rear
-BC P1 LCA's
-ASR Subframe Brace
-Tanabe Sustec 20mm Rear Sway Bar
-Blox Adj. Endlinks
-BC P1 Front & Rear Camber Kits
-S2 Front STB
-PW:JDM Rear STB
-Energy Suspension Hyper Flex Master Bushing Kit
Wheels and Tires:
-15x8.5 +17 Klutch Republik SL1 Bronze and Black wheels
-Kumho 195/45 tires
-Extended Studs +20mm
-Yonaka Gold Aluminum Lug Nuts
84mm YCP ITR reps Hastings Piston Rings P8R milled .010 3 angle OEM valves Port match,polish Crane 0016 cams Crane Springs Crane Ti Retainers ARP rod bolts ACL rod bearings OEM Rods re-sized ARP Headstuds OEM P8R 2 layer HG Blox V2 Intake Manifold ported to 68mm Blox 68mm TB Precision 650cc Walbro Fuel Pump Accell Coil Hondata Heat Shield P2R TB thermal gasket 3" Exhaust Magnaflow Muffler Magnaflow Resonator 8lb Fidanza Fly ACT 4 puck unsprung Mishimoto Radiator Mishimoto Hoses Mardyne 13" 1300CFM Fan SUNAuto Voltage Stabilizer and Grounding CTR Pulley B&M FPR Professional Products Fuel rail -6AN Marshall Liquid fuel pressure gauge HardRace Mounts LS trans Color matched valve cover Custom -6 fuel line Russell In-line fuel filter Custom clutch line Blox Oil Cap Blox Radiator stay Blox Magnetic drain plugs Blox Cam seal NR-G Hood Supports
Suspension Modifications: BuddyClub P1 Upper Control Arms F&F Type 1's corner balanced Susp. Tech. 24mm front sway ASR 24mm Rear Sway ASR Sub Brace Function & Form Polished LCA's Benen 3pt Strut bar #1 Rear Strut Bar (Soon to be pwdjdm 4pt) Blox Rear Camber Kit Rear Disc Conversion Hawk HP Pads
Wheels/Tires Modifications: 16x8 Varstoen
205.40
Interior/Exterior Modifications: UKDM CRV Manual Cluster ProSport Gauges OEM Floormats MoMo Dead Pedal MoMo MonteCarlo 320 ARC replica knob Sparco R100 seats Sparco Rails/Brackets OBD-II to OBD-I Conversion Suede DIY Door panel insert Suede DIY Armrest Suede Shift Boot Backseat Delete Custom Trunk Deck LED Map/Dome/Trunk lights Custom Trunk Lift supports P-75 Chipped Neptune Greddy Timer Pioneer DVD4200 Pioneers in the corners Kicker 300.1 Kenwood 10 in floor box 5% Tint on rears, 20% on doors, 50% on windshield
-2006 K24a2 longblock from Hmotorsonline.com
-DC5R transmission
-Civic Si (RBC) 50*VTC gear
-K-Tuned Magnus intake manifold
-K-Tuned Big Tube header
-K-Tuned TCT cover
-K-Tuned Race spec shifter cables
-K-Tuned K24 water neck version 2
-K-Tuned Thermostat housing plug
-K-Tuned Billet RSX shifter
-K-Tuned Billet shifter base
-K-Tuned Billet bushings
-K-Tuned Shifter cable firewall grommet
-K-Tuned #1 of 5 Raw high flow fuel rail
-K-Tuned Raw k24 oil dipstick
-K-Tuned battery tie down
-K-Tuned brake booster line
-K-Tuned 5th gear lockout
-K-Tuned Pro series traction bar
-K-Tuned 90mm throttle body
-K-Tuned Hall Effect TPS
-K20a2 Oil pump
-Ported PRB head
-Supertech 12.5:1CR 88mm pistons
-Supertech titanium valve springs
-Supertech valve seats
-Supertech retainers
-Supertech bronze maganese valve guides
-Supertech valve stem seals
-4 Piston K600 camshafts
-Walbro 255lph fuel pump
-Cometic headgasket
-Custom 3.5" cold air intake with velocity stack
-CNS custom works Black chrome valve cover
-Downstar engine/ trans/ bell housing/EKK2 mount/subframe/water pump housing/shock tower/front lca/rear lca/EK chassis kit/license plate kit bolts with beauty washers on everything
-Spoon Sports carbon kevlar plug cover (discontinued version1)
-Spoon Sports oil cap
-HPT timing chain guide
-OEM Honda CRV engine bracket
-Donkey Power Injection 650CC injectors
-Karcepts KPS02 AC/PS delete
-Bisimoto Evolution 8.4lb flywheel
-Bisimoto Action 2MS dual diaphragm 6 puck caged sprung clutch
-Insane Shafts 500whp EKK2 swap axles
-K20a2 halfshaft
-HAsport 70A EKK2 motor mounts
-Hondata thermal intake manifold gasket
-Hondata KPRO version 3
-Vibrant braided lined flex pipe
-Hybrid Racing polished fittings
-Hybrid Racing fuel pressure regulator
-Hybrid Racing fuel pressure gauge
-Hybrid Racing inline fuel filter
-Hybrid Racing tucked fuel lines
-Hybrid Racing braided clutch line
-Hybrid Racing engine grounding kit
-Wire-worx Stage 1 OTVC engine harness
-Wire-worx Plug and play K conversion harness
-KTeller 3" stainless steel piping
-K-Tuned turn down muffler
-Griffin k swap full sized radiator
-SPAL 12" fans
Tuned by JTran at JTran Motorsports 291hp @9000rpm /210tq @4900rpm
Interior:
-Buddy Club P1 Limited version 2 bucket seat
-Takata 340MPH racing harness
-Spoon Sports wide rear view mirror
-Spoon Sports Gen.2 steering wheel
-Works Bell Rapfix II quick release
-Works Bell QRS adapter
-Checkerd Sports polished hub
-Carbing/Okuyama high grip shift knob
-K-Tuned white delrin shift knob
-Mugen carbon fiber spherical shift knob
-Seeker heavy weight shift knob (rare)
-K-Tuned Lagrima shift knob
-Mugen Si shift knob (rare)
-Mugen CR-Z shift knob (rare)
-Single DIN block off
-EJ8 EX gauge cluster
Exterior:
-Spoon Sports lip spoiler
-Spoon Sports windshield wiper blades
-Spoon Sports windshield banner
-EK9 CTR headlights
-EK9 CTR grill
-HOP Civic EK9 mirror block off plates
-Magical Racing RR twill carbon type 4 Mirrors
-Volt Digital 4300K H.I.D.
Suspension:
-Function and Form Type I version 3 coilovers
-Function7 lower control arms
-Function7 subframe brace
-Buddy Club P1 rear camber arms
-ASR 24mm rear sway bar
-ASR spherical endlinks
