that f**king sucks. nothing like destroying a several thousand dollar motor build from a $5 part breakingd16y8:
75mm YCP vitara pistons
eagle h beam rods
arp head studs
crower turbo cam
crower titanium retainers
crower valve springs
Tuned on Hondata s300, Lasted 2.5 years on 20ish psi with a t3/t04e .48 .60a/r turbo. Eventually had to rebuild it because the wrist pin retaining clips broke and allowed the wristpin to walk out and hit cylinder wall.
Now how would the wrist pin and clips just break like that? Bad install?d16y8:
eagle h beam rods
arp head studs
crower turbo cam
eh, s**t happens. I was pretty pissed at the time thoughthat f**king sucks. nothing like destroying a several thousand dollar motor build from a $5 part breaking
Its not the wrist pin that breaks, it was able to walk out and start rubbing on the cylinder wall. Not quite sure why it happened, I've heard of 2 or 3 other cases where it happened. I guess its just luck of the draw.Now how would the wrist pin and clips just break like that? Bad install?
Would a bad clutch ever mess with street/dyno tuning results?JDM B18B
stock block, stock head
Garrett T3/T4 .60 trim
Injector Dymanics 725cc injectors
Running @10psi, since September. Running perfect so far minus a bad clutch (slipping). So I guess we'll see how long it lasts *knock on wood*
Picked up a built B18 head (crower double springs, titanium retainers / keepers. Going to get a set of BC turbo cams and adjustable gears, and do a mild build on the bottom end.. and go from there.
if the clutch slips, its not going to rev as high.Would a bad clutch ever mess with street/dyno tuning results?
I can vouch for that lol. I was even surprised when I saw you and you told me there was no tune.the wastegate had a 6 lb spring according to the person i bought it from, but its a deltagate mark 2 by turbonetics, and i never knew what kind of horsepower my car had because i never dynoed it. So.. yea no detonation. I'm just lucky like that
