I notice everyone saying the b16 motors are gutless.. so I'm having second thoughts on building one up and maybe going to a b18 block? What do you guys think.
Shady peopleWhat's the biggest threat from buying a used block?
Youre in honda-land dude, no one is safeHaha. Just moved away from Houston so I should be good.
Either low compression pistons and boost that bad boy or stroke the motor to a 1.8 and build n/a
ls vtec turbo lol. yes it was built it had rods pistons and sleeves, and b16s are gutless in there stock formWas it a build ls? Na or boosted.
I might argue with you on the worse gas mileage with the shorter gearr ratio. CIty driving my 99 GSR got 33mpg easy, but say I took a road trip or something of that sort the best I could do was 38 MAYBE 40. I figured it was due to the fact that in city drivning the gsr trans kept the engine within the powerband and thus I didnt need to stay in the throttle as long to get up to speed. ANYWAY, the OP's best bet is to figure out his goals and what he wants to do with the car. This is always step #1 and I don't know what no one has menioned it yet.If you want to go cheap(er) and not mess with the motor much and still have a ton of fun, I would recommend the GSR swap. I bought mine as it sits with a skunk2 intake manifold, intake/headers/exhaust, a little bit of advance on the timing and a tune on 93 octane. Dynoed 176 hp to the wheels, 6 hp more than its rated for stock at the crank (most GSR dyno pulls I've seen on here are about 145 hp to the wheels in stock form). I even have a "weak sauce" LS trans on there and it's plenty fast for a DD. I imagine putting a motor together like that with a GSR or, even better, a B16B trans (which is the shortest geared version) would be plenty fast unless you plan on tracking the car or are hell bent on putting more than $5000 into the whole thing. With the LS trans I get about 33 mpg combined, you'd get less with the quicker trans. And the torque is about 30% greater than you'd get in a B16. It's pretty great overall.
The bonus is, with everybody going K, the GSR motor has dropped in price and increased in availability. Plus, you can plunk it right in there, no cutting or welding required.
