You kept the IACV on the manual, right? Making sure, because if you swapped the one over from the automatic, 99-00 IACV's are different between auto (3 wire) and manual (2 wire).Also the manifold and thermostat housing are both off of the manual.
I agree with the others on checking your throttle cable. Pull your intake and take a look at the throttle plate. Make sure it's fully closed. I know you said you cleaned the IACV, but if the throttle plate is dirty, clean that up too.
I had a P0505 issue with my RSX last year, along with an idle higher than normal. I cleaned / replaced IACV, checked the cables and hoses, etc. It turns out the TPS was off calibration.
