Amazing what difference new rims make...
there in really good shape too... other than missing one center capAmazing what difference new rims make...
Not everyone thinks its cool to scrape frame I guess.Low cars complaining about bad roads. I'll never understand that.
like i said before.... my car is at the level where it doesn't scrape.... but if i go any lower right now it will scrape on the road........ and what is "doing it right"????? when the roads get better i will go lower but till then i am happy the way it sits.....O P is floating from scraping frame. And if its such bad roads, why lower the car. And if its lowered, why not do it right so that you don't scrape.
nah..... i am not down to ruin my car my ripping off the exhaust.... lol yes its lowered and i have to watch where i drive... but laying frame in New England is not practicalNot everyone thinks its cool to scrape frame I guess.
Its not my chassis i am worried about scraping.... its the exhaust that hangs low so spring rate isn't going to do a thing..... when the frost comes out of the ground i wont have this issue and i can go lower with out any worriesdoing it right (in this sense) is by having a spring rate and dampening force that is adequate for the ride height. As you go lower, the spring rate and dampening should compliment the height which will keep you from scraping. Things like extended top hats to increase shock travel at low ride heights help as well. Plenty of cars much lower than you without scraping issues.
with the ws2 the lowest point is the resonator.... I work at a exhaust shop and there is no way to bring that exhaust up any higher without cutting the hangers off and welding new ones on.... and thats not a option IMO.... spring rate is not going to help with the "problem" i have with the exhaust...A higher spring rate will actually keep the car from dipping low enough to scrape the exhaust. The ws2 lowest section is the resonator, which when properly installed with new hangers doesn't hang much lower than the jack points...and you're nowhere near your jack points.
nothing is Fu$%ked up on my car its simple.... its ground clerance from the exhaust ... its like 2 inches from the ground... we can back and forth on this issue and your not going to convince me that my problem is spring ratemy old coupe slammed on 15's with apexi ws2 exhaust WITHOUT scraping. Also with a b series in it and a long 4-1 header.
if OP is scraping, something is f*$ked up. Nothing custom done to the suspension and nothing modified on the exhaust for clearance.
Op said he wants to go lower, then has the excuse of ground clearance issues....ground clearance issues that I never had with the same low hanging exhaust. So I don't understand the clearance issue got winter or not. if the winter roads were so bad, its pretty stupid to lower the car in the first place and just waitUpdated 3/7/12
Dropped the front a lil more looks better... got to go more
