it will be tuned as much as you can with a fmu by a professional, (not me)
no there are people that have had good luck with it. but they are very conservative with there fmu, and theres more hp to be made with say hondata or uberdataboostedb16 said:so know one has ever had a fmu and the car ran fine
idk if its only my brothers car, as for its the only car ive been in while detonating, but when his would detonate the car would start jerking in short bursts and he would let off the gas and turn down the boost a bit. but that was when he was running 14psi with stock fuel except fmu on a t25(14psi is the most it will push and he was trying to blow his motor)Shiznit said:ahemmm..... BOOM. youll know when your car is detonating. and if it is i would immediately pull over and turn the car off
take it easy with the fmu and save for hondata, and yes it is very possible to blow your engine with hondata if not tuned correctly.boostedb16 said:can any body answer my last two questions, the last reply said someones brother ran 14psi on stock fuel, i will be changing fuel pump, and how much tuning can you do with a fmu
no you do not have to chip... it goes into the ecu wiring harness and works with obd2... but from what ive read the emanage is only good to 13 psi? because it runs off of the stock fuel map... if u want to run higher.. u could chip ur ecu if its obd1 and run crome or urberdata.. or get hondata if the ecu is obd1... but if its obd2 u can get the emanage ultimate which i hear has its own fuel tables and maps to run off of so it can handle higher boost... someone may be able to fill in more as i dont know alot on it...boostedb16 said:but with e manage do you have to chip ecu
