[civic] said:
Ok, time for my questions..
I saw some pricing for your labor and had a few more..
How much for you labor if I wanted TSX projectors and using OEM headlamps? I can probably provide you with the HIDS. How will the connections be? Do I have to splice into the stock wiring system to get this to work? What about Bi-Xenon, won't work huh?
What is the average prices for TSX HIDS? I want to know so I can offer a lower price at the junkyard. If the price is too high for tsx, what other projectors/hids do you reccomend on getting?
Hey $200 for stock housing and i will paint the housing black if you want.
TSX projectors are going to cost you around $200 - $280 depending on where you buy it, if you can find one @ junkyard try to get it for cheap. So on TSX projectors it varies. Bi-Xenon will be bit harder on wiring system if you want bi-xenon that's not a problem for me but you'll need to do the wiring through your harness and crap.
Splicing your harness question i have
1)Yes you can go ahead and do that
2)I can make you a little harness so it'll be plug & play for extra $10 that's just parts no labor charge
3)You can run it yourself to the battery and have a switch or whatever.
If you can not find a good price for TSX i only have 3 i do rec.
1)Audi A4/S4 H7 Valeo DOT or even ECE with H7 adapter
2)Audi A6 Single not RS-6
3)BMW E46 3Series
