More Confusion! Candlepower!
Candlepower is a way of measuring how much light is produced by a light bulb, LED or by striking an arc in a Carbon-Arc spotlight. Is it a measure of how much light falls upon an object some distance away? No. That's illuminance. Is it a measure of how well we see an object that is illuminated by that light source? No. That's something all together different, and we are not going there!
Nowadays we use the term CANDELA instead of candlepower. Candlepower, or CANDELA is a measure of how much light the bulb produces, measured at the bulb, rather than how much falls upon the thing you want to light up. Further confusing the matter is beam focus. That's how much candlepower can be focused using a reflector/lens assembly. Obviously, if you project all your light bulbs intensity at a given spot, or towards something, it will be more intense, and the illuminance will be higher.
And here comes the confuser! A candlepower as a unit of measure is not the same as a foot-candle. A candlepower is a measurement of the light at the source, not at the object you light up.
And a candela is the metric equivalent of the light output of that one candle, based on metric calculations. And since using a candle is rather imprecise, the definition was amended to replace a light source using carbon filaments with a very specific light source, see the following:
The candela is the luminous intensity, in a given direction, of a source that emits monochromatic radiation of frequency 540 x 1012 hertz and that has a radiant intensity in that direction of 1/683 watt per steradian.
The above from the National Institute of Standards Reference on Constants, Units, and Uncertainty.
Candlepower is a measure of light taken at the source-not at the target. Foot-candles tell us how much of that light is directed at an object we want to illuminate.
Now, lets convert the lumens, a metric unit of light measurement, to candlepower.
We understand a candle radiates light equally in all directions, its output, in this consideration is not focused by any mechanical means (lenses or reflectors). Pretend for a moment that a transparent sphere one meter in radius surrounds your candle. We know that there are 12.57 square meters of surface area in such a sphere. Remember your Solid Geometry classes?
That one candle (1 Candlepower/Candela) is illuminating equally the entire surface of that sphere. The amount of light energy then reflected from that surface is defined thusly:
The amount of energy emanating from one square meter of surface is one lumen. And if we decrease the size of the sphere to one foot radius, we increase the reflected energy 12.57 times of that which fell on the square meter area.
LUX is an abbreviation for Lumens per square meter.
Foot-candles equal the amount of Lumens per square feet of area.
So, that one candlepower equivalent equals 12.57 lumens.
And for you figuring out LED equivalents, first you must know how many lumens your LED's each produce. Then divide that value by 12.57 and you have candlepower of the LED. You don't have foot-candles, remember foot-candles are illuminance. And we are measuring radiance.
Summing it all up:
Candlepower is a rating of light output at the source, using English measurements.
Foot-candles are a measurement of light at an illuminated object.
Lumens are a metric equivalent to foot-candles in that they are measured at an object you want to illuminate.
Divide the number of lumens you have produced, or are capable of producing, by 12.57 and you get the candlepower equivalent of that light source.
We've now converted a measurement taken some distance from the illuminated object, converted it from a metric standard to an English unit of measure, and further converted it from a measure of illumination to a measure of radiation!
This has been an ideal proof of the superiority of the metric system. Then again, the metric system is a product of those wonderful folks that brought us:
Renault, Peugeot, Citroen, and Airbusses. Not to mention simply awful Bordeaux.
And, if you're happy with this, send those little gems to:
Robert H (Doc) Bryant
3408 Thomas Ave
Midland, Texas 79703-6240
I hope you have enjoyed this as much as I have. You ought to see me up in front of a classroom. My classes are absolute laugh riots. But people learn!
