dude swap factory motor, or port and polish you head, and spray 100 direct port!!!!!!!!!!!!!Originally posted by K-west
so in ur opinion do u think a ls/vtec is a good thing or it jus better to swap a factory engine ?
Originally posted by Goldberg316
Since the b20 can only rev to 8000 safely, can you put in new or different rods to make the lenghth of the rod better for a high rev. Hopefully thats a little better
i thought the red line of the b20 was 65 mah bad!!!!!!!!!Originally posted by iamgod
d00d, the RODS are not what is affecting it, it is the stroke, the stroke is determined by the CRANK, and the B20 can safely rev to 7200 not 8000
Originally posted by edhgreatone
ok wait i got a question of i get an si motor b16 and i put a crv bottom end on it.... with the mess up my vtec??? if you can only rev to 7 and SI's redlide at 8 then won't they mess up everything?
so whats the best block to do it on???? if your going all motor
what is the best block to do it with if you want to go all motor.... what is the fuel cut off for the crv block..... what would you redline at?
1.54. 1.75 is "ideal", and r/s ratio doesnt have much to do with hp, it has to do with engine geometry and the forces and dwell times at tdc/bdc. it has the same r/s as an ls motor, and almost the same as the b18c in gsr's/itrs (1.58 for them). in a street motor, the r/s doestn have much bearing, as it only really comes into play at extremely high rpm- generally 9000+ is when you start to worry about r/s.black89crxls said:dude once you feel the power of the strait b20 you will understand. also you dont need more TQ at higher RPM"s cause the rod stroke is crappy1.76 if im not mistaken and you dont want to rev no higher than 7800, well at least im not, ALSO dont change the crank honda cranks are bad ass forged, the only other crank you could use is a stroker which is stupid cause it makes the RS worse,you are 15 i seriously doubt you will need any thing more, if i were you i would highly suggest going with a strait ls, maby b16 pistons, higher compression, and a port and polish, b18s have very much TQ not to mention i have a long block for 400, also get some experience behind the wheel first then go big, also you will run into traction problems
yea my bad i got them mixed up, thanks for the correction,handlebarsfsr said:1.54. 1.75 is "ideal", and r/s ratio doesnt have much to do with hp, it has to do with engine geometry and the forces and dwell times at tdc/bdc. it has the same r/s as an ls motor, and almost the same as the b18c in gsr's/itrs (1.58 for them). in a street motor, the r/s doestn have much bearing, as it only really comes into play at extremely high rpm- generally 9000+ is when you start to worry about r/s.
