You shouldn't have any problems then. The y7 and y8 blocks seems to be identical. If your car had a d16y8 in the first place, it's very simple, no rewiring or any of that other things necessary to be done. Just bolt on and it should be fine. You may have to tap a hole located in the same postition as the d16y8 block to put in the knock sensor, but everything else should be just like replacing it in with another y8.anfrey said:i dont' have any y7 manifolds, just manual y8 manis, as a y8 is what i used to have. i'm buying a y7 longblock and swapping the head from my current y8 onto it.
Swaping a ZC or a doing a MINI-ME or even a D16Y8 is gonna net you about the same results.honda man said:first of all do you know how much hp difference u had after the mini me swap. and i have a D15B2 in my 89 hatch and i seen this and i didnt know if it would be better to do the mini me swap or if i should go ahead and do the DOHC ZC Swap like i had planed. if it would be better for me to do the mini me and build that how much am i looking at to do the full mini me swap in parts?????? and would it be worth it in a 89 hatch?????
Please read the entire thread.civic939 said:is there anything like the mini-me that can be done to a stock d16z6?
My old D16Y8 eat ZC/mini-me for breakfastnd4sped said:Swaping a ZC or a doing a MINI-ME or even a D16Y8 is gonna net you about the same results.
The advantage of swapping a D16Y8 is that its gonna have aubstantially less miles than either the ZC or a MINI-ME from your D15.
Downside is that the D16Y8 is gonna be OBD 2. Though that can be fixed.
The onyl real advatage of the DOHC ZC is, well its DOHC. So you have better cam adjustment.
Personally you are better off doing a D16Y8 swap. About same power as what you will make from the other swaps stated above and its got less miles.
Nitrous, Turbo or Supercharger. Thats about it.civic939 said:my question was is there anything that i can bolt on to make as big change of power from my z6 that the non vtec to vtec makes? thanks.
Ok a quick run down since Im going to sleep after this.anfrey said:teach the man about headwork
If you want better numbers for less money int ehlong run. Swap a DOHC in.honda man said:well i was realy wanting to drop a dohc in it but i real jsut want something that is gunna be fast as hell i can build to be faster and that can handle it i wnating to really push some hp out of what eveer motor / swap i do im kinda of thinking about doin the mini me to see what its like........ and sugestions or would u say not to do the mini me just go ahead and swap??????????
What exactly are you asking?watup im a dude looking to do for what u did to ur stock d15b7. u outta help the brothas out their increase car potential man.
