Remote Start
blackblurrb18
Originally posted by 95civLX
so....I got a remote start for a manual tranny for x-mas and it's been sitting in muh room since. No electronic shop will install it for me b/c of the liability or some stupid crap like that. I'm tired of looking at it. Does anyone have a remote start? Would it be hard to install it myself?
Dude I can help you out I have installed a ton of those. To by pass the clutch all you have to do is find the clip that goes to the clutch pedal and put a jumper on it so it can complete the circuit. Also to find out where all the remote start wires go you just have to look at you ignition wires they are all labled. Oh and it would not hurt to learn how to use a volt meter and a test light also find a relay take it apart and see how it work that help out alot. I can tell you exacly what wires do what in you car. I just installed P/W and door lock on my 94 civic hb si. I know it can be stressful and just looking at the wires it's like man where do i start.
but if you need any help let me know
boricuacvc
El Gistro Mami!
i work at best buy and they install those everyday. u can talk to one of the technicians and as a side job they might install it for you.
DMac2000EX
a friend of mine from a local shop is installing mine tommorow... ill tell u how it goes... mine is a hornet alarm remote start keyless entry etc... i forgot the model #... good luck on the install
rUdGrICk
92'cIvIc vX
i got one but it came with the car ,i luv it its hella tight.i dont know how hard it is but u can givel the installer a contract saying theytake no responibly for it!i think its b/c if u have it in first gear and u try to start it,it will jump and try to go!good luck
Akiahara96
back!
... if a shop installs it.. everyone I've seen.. it will not start in gear.. you have to be in neutral. it's a protection thing since people don't realize that your car will want to go. ;)
how the hell do you do that in an auto???
I have remote start and I love it. ;)
JDMRacer24
You need to go to another shop because now that alarms are made for manual cars they have to install it. also it could be that there dumb and dont know how to do it. Common sense if the remote is for manual transmission means that you have to do a certain procedure before you get out of the car in order for it to remote start if you dont do this it will never start. the only thing you have to do is bypass the clutch with a relay you can find info online bout that. it is a pretty easy install but i would leave up to someone that knows what there doing dont want to fry ur car but if your brave do it you can find wiring diagrams online. the only thing you have to do is make sure ur tach, parkiing brake and bypass clutch is connected. you can trust me im a certifiied installer mecp
JDMRacer24
wire colors for ur car
12v--- + white
Start-- + black/white
Ign--- + black/yellow
acc--- + yellow
tach-- (ac)blue at 2pin connector near distributor or that little test connector on drivers side with 1 wire in it
brake---green/white at brake switch
parking lights--- + red/black @ FUSEBOX OR DRIVERS KICK PANEL
POWER LOCK GREEN/WHITE (TYPE B) @ 2-PIN BLUE PLUG, BEHIND FUSEBOX
POWER UNLOCK GREEN/RED (TYPE B) @ 2-PIN BLUE PLUG, BEHIND FUSEBOX
DOOR TRIGGER LIGHT GREEN/RED (-) IN DRIVERS KICK PANEL
