ifish4tuna
Hey 1st post here. Just passing along some intel and a service recommendation.
I was searching about gears grinding when putting my Civic in reverse. I am a multi honda owner driving nearly all of them to 300K miles, and buy them for reliability reasons, and ease of maintenance when needed. I buy all of them used with 60-100K miles.
I'm planning to drop off my 2004 Civic EX with 98,000 miles to my son in North Carolina in the near future. It will be replacing the 2004 Civic EX which has 296,000 miles, and is now leaking oil considerably and not worth the extra $/work to resolve.
Prior to delivering I wanted it in tip-top shape. The car had been grinding when putting in reverse more and more. I bought it with 62,000 miles used 1 year ago. It had the problem then, but has progressed to be very frequent. Like 4 out of 5 times. I can avoid as has been discussed on this forum and others, but going into first, then reverse, but who the heck remembers to do that? Only after hearing the grind.
It has also been discussed on this forum and others, that this is normal behavior for Honda's because they don't synchronized. That's BS. The car down in NC w/ nearly 300,000 miles has never had a problem grinding when putting in reverse.
I brought the car to my local AAMCO in Portsmouth, New Hampshire - Service Manager's name is Paul, and after considerable diagnostic, they have identified it is a linkage issue. Paul sent me a picture of the lever showing the visible wear. There is a part that it engages with that is also worn. Once photopbucket comes back on line I will post the picture. Paul and his mechanic also confirmed (as did my local Honda dealer), that there is a synchronization gearing which should avoid the grind.
As a note, I HIGHLY recommend this shop if anyone needs service. They are thoughtful, honest, and have integrity. At the end of the day I dropped it off, while still a puzzler, they spent 15 minutes with me going through the diagnostics with me showing me the tranny on the bench.
I give this AAMCO shop an A+ rating.
Ed
Ed
