Manual and Yeah, on fuse 19 it's like the fuse itself but with a wire connected to it that seems to go to the transmission I'm not really sure.Auto or manual?
Did you check the fuses first? Fuse 19 under the dash I believe.
Can also be reverse sensor on the tranny IIRC.
see this is what's on fuse 19 it's the red wire.And you're SURE that fuse is good? Follow that wire to the trans, or wherever it goes. There may be an inline fuse that's blown, or the wire could be damaged. It sounds like that wire may be going to the reverse switch on the trans.
