Ryans Official "Build Up" Thread
ShinsenTuner
CC's Youngest OG
92-00 Civic pedals fit 94-01 teggy's?... oh yesss.
Hecz
what happened to the hseries?
Szady
D-Series Master
Yep. You have to adjust the pedal height tho. You have to keep the pedal/brackets together. Like say 94 5spd brake pedals sensors are in a slightly different location than the 2000 5spd bracket.
denracho
man ... i have a 2000 ex... is the flywheel cover interchangable for 96-00 or 99-00 is diff from 96-00..im confuse..can someone clarify this?
Szady
D-Series Master
Yea, the flywheel covers are all interchangable between D series. :thumbs up
As far as an update for me, I picked up a short shifter. No pics yet, b/c Ive been massively busy w/work and getting married.
denracho
here's my list so far..
2x ex trannys-240 for both
manual vss-free
reverse sensor-free
99-00 p2p manual ecu-15
92 cx starter- free
clutch pedal, hydro lines to slave kit, upper tranny bracket and 2 wire iacv plug - 90
97 shift linkage -free
mint 99 ex complete intake manifold-50
b&m dual bend short shifter- 30
exedy oem clutch and pressure plate - 30
oem flywheel- 15
front bracket with mount- free
3 honda mtf- free
flywheel cover(need)
TOTAL: $ 470
i just need to order every bolt that i need.. maybe another 100 bucks for everything..
im saving a lot of money cause i try to wait till i can get a great deal...gudluck homie
Szady
D-Series Master
Updated the first post. :thumbs up
Sundown
ej6civic27 said:
Lessons learned so far:
- 5th Gen Civic pedals/brackets fit in a 6th Gen Civic.
- Find someone who's really short/small to crawl up and unbolt/bolt in the pedal assemblys.
- A 6' 2", 220lbs person dosent fit very well under the dashboard of a Civic
- To get the gas/brake pedal bracket out/in, you have to drop the steering column
Shiet, i can add a LOT more things to that list...
-Make sure to take the dowell pins out of the block/auto transmission, they will keep the trans from going on, and will piss you the hell off..
-you actually can cut the heatplate that's under car from inside the cabin
-make sure your friends that can help you can help atleast for 2 days, or how ever long it takes to take the old trans out and put the new one in.. There's no way I could have done mine alone, there's just too much s**t.
-depending on what transmission you use, some s**t is gonna line up weird/not line up at all. For example, I have bolts on my tranny that bolt up to nothing on the block because the tranny is from an eg civic..
-obviously, make sure there's atleast one working vehicle where you are because you WILL be making a trip to the store.. that's a guarantee
-the flywheel cover wont go on after the transmission is on.. or atleast its nearly impossible
-get a ball joint seperator. It looks like a small pitchfork. I swear that thing worked MANY jobs such as prybar, ball joint seperator, wedge, etc etc etc...
there's plenty more, ill let you know after I make my thread..
Szady
D-Series Master
Well, I have a Y7 tranny, so everything will bolt up just fine. Im just worried about idle problems, and IAVC problems. I have a 5spd one, so we'll see.... :what:
:lol:
Genuine Rolla
Its PETEY PETE, y0!
shift knob looks sick. Can't wait to help ya out this upcoming weekend.
Szady
D-Series Master
Genuine Rolla
Its PETEY PETE, y0!
it'll be dope.
I'm herra looking forward to it.
BrakeLights
good luck with it and post pics and any problems you have man! im pretty jealous :lol:
Szady
D-Series Master
Why are you jealous? Didnt you already do your 5spd conversion?
ImportFan1
Super Moderator
looking good man. cant wait to see it finished.
