Safe Boost
1999CivicEX
My friend has a 99 ex with d16y8. He is going to put eagle rods and srp pistons into it. Lowering his c/r to 9.0:1 from 9.6:1. How much boost can he run safely??
Sleeper
92 4doorSleeper
wno one can tell you. You dont rate by hp. You rate by hp/tq. THe better question is how much power can it hold... still cant tell you cuz it has to many verables.. turbo size(makes diffence in powerband), injectors size, tuning method, & other s**t
1999CivicEX
He has the edelbrock turbo kit. the one that is set to 7-8 psi. if that don't help then I really don't care because he is to lazy to come here and ask
WalterRonny
Amante de los EG's
no all depend that you put rods and pistons betters , depend too to do a good tuning , which injectors do you will use.. what turbo...etc.. cuz you can to blown your engine runing still to 4 PSI though you runing with this pistons and rods..
1999CivicEX
I know he is putting in eagle rods and srp pistons thats all I know I guess he is screwed because I don't know all the info on his setup.
I know the rods can handle 550 and pistons lower the c/r to 9.0:1
Sleeper
92 4doorSleeper
your almost saying the same thing i said.. but in the european guy broken english way :lol:
Sleeper
92 4doorSleeper
the rods will handle 550... the rest of the motor wont lol
WalterRonny
Amante de los EG's
jhahaha ,sure! now i see your answer and yes is almost the same thing .. such bad is my english ? :cry:
1999CivicEX
Went to the edelbrock website and got the specs on the turbo also talked to him on the phone
Garrett GT28R Ball Bearing Turbocharger Assembly with Integral Wastegate..... #15020
SPECIFICATIONS:
Displacement range: 1.6-2.5L.
Output Range 200-280 horsepower.
Compressor Wheel Diameters – 1.83” inducer/ 2.37” exducer
Compressor Wheel Trim – 60
Compressor Housing A/R – .60
Compressor Hsg. Attachments: Inlet: 2-bolt flange
Outlet: 3-bolt flange
Max Compressor Flow – 31 lbs/min @ 2.5:1 pressure ratio
Turbine Wheel Diameters – 2.09” inducer/ 1.64” exducer
Turbine Wheel Trim – 62
Turbine Housing A/R – .64
Turbine Hsg. Attachments: Inlet: Standard 4-bolt T25 flange,
Outlet: Standard OEM 5-bolt T25 flange
Oil Inlet – Inverted Flare 7/16-24 thread
Oil Drain – Standard 2-bolt T25 flange
He said he plans on using the stock injectors because he doesn't know if he should go bigger (I am guessing bigger don't know much about F/I as you can tell) pistons rods you know about already. ARP head studs.
He wants to know the following.
1. How much boost on good tune
2.Bigger injectors if so what size
Sorry for all this crap I don't care he does lol so if this doesn't yeild something that can produce answer then this can be closed
bizoneoeh
Ex-Gang Member
If your homeboy is gonnaa throw in some rods and pistons he can go a little higher than 7-8psi. Maybe 15lbs or so :what:
SI-vic lover
i 2 am lookin torwards the edelbrock kit for my 94 ex and wonderin the exact same things..............dont know 2 much bout turbo's either............any help would be great
bizoneoeh
Ex-Gang Member
well, if you have any questions feel free to pm me. I can help you as best as I can :D
Sleeper
92 4doorSleeper
Hes not getting far at all on stock 240cc injectors. maybe 165-170whp @ 42psi fuel.
@ 40psi fuel press. the sizing is around. & around 90% duty
310cc 200~220whp
370cc 220~280whp
440cc 280~330whp
550cc 330whp~380whp
660cc 380whp~425whp
720cc 425whp~475whp
880cc 475whp~525whp
980cc 525whp~600whp
1999CivicEX
310cc 200~220whp
370cc 220~280whp
440cc 280~330whp
550cc 330whp~380whp
660cc 380whp~425whp
720cc 425whp~475whp
880cc 475whp~525whp
980cc 525whp~600whp
Thanks
1999CivicEX
alright, so what do you think 15lbs will put out
bizoneoeh
Ex-Gang Member
Yeah, that might be good. Yo might be able to go a little higher. It's hard to say tho, it depends what size turbo and what kind of tune and s**t like that
1999CivicEX
Well its a Garrett GT28R turbo and he plans on tuning with chrome, he would like a ruff estamite so he can get the right injectors
Shiznit
Stickin it to the Man
we need the size of the turbo... PSI is irrelevent without knowing the compressor size of the turbo.
1999CivicEX
Shiznit
oops... sorry i didnt see that post
heres the compressor map. off the top of my head i think the red line of a y8 is around 7800 correct me if im wrong... so after doing all the calculations heres where your turbo stands at redline
after futher calculations i figured out he will be at around 240hp at the crank @ redline... now someone that knows about pistons and rods can tell you if 240hp on the block will be too much stress. but you have to consider redline is where your car isnt in its power band so his max power will be higher than 240
