Safe Boost
Shiznit
Stickin it to the Man
around 200ish @ 7800rpms give or take 10hp. remember these calculations vary from car to car and are dependant on a number of variables. you should be fine at 7psi
Sleeper
92 4doorSleeper
6800 is stock Y8 redline & 240cc injectors can not surport 200whp
1999CivicEX
Okay guys thanks for all the help He learned something new as did I
Once again for the help
Shiznit
bah im tired of doing the stupid calculation... a stock D-series block cannot handle much more than 200whp. so as long as youre under that and have a good tune, you will be fine. or your friend will
WalterRonny
Amante de los EG's
Shiznit said:
oops... sorry i didnt see that post
heres the compressor map. off the top of my head i think the red line of a y8 is around 7800 correct me if im wrong... so after doing all the calculations heres where your turbo stands at redline
after futher calculations i figured out he will be at around 240hp at the crank @ redline... now someone that knows about pistons and rods can tell you if 240hp on the block will be too much stress. but you have to consider redline is where your car isnt in its power band so his max power will be higher than 240
nice calculations, how did you do it?
Shiznit
well first you have to calculate CFM in lbs/min the formula for that can be found here http://cybrina.mine.nu/MR2_Docs/compressor_flow_maps.htm
then you plot CFM with the pressure ration on the compressor map and it will give you how efficient you turbo will be at a given RPM range. (the RPM is selected when youre finding the CFM)
after that i believe the conversion from CFM to HP is 1.6CFM = 1hp. i got that from google so it may be wrong. that will give you the HP your turbo will be creating if it were 100% efficient. theres one other calculation that i cant find at the moment that will tell you how much HP your car is really making.
again HP created by a turbo is dependant on a number of variables. my calculations calculates it for when it is in a Vacuum.... but is somehow getting oxygen lol
Revolver
Oct 10th
Really?
http://www.honda-tech.com/zerothread?id=1478127
D series:
1. Jeff Evans tuned D16z6, 308whp/262tq, neptune, GT28RS
2. BoostedED9 D16Z6 302whp 251wtq
3. nerdsports Y7block/Z6head 273whp 224tq
4. King-Kong D16z6 @ 264p/240ft.tq @ 13 psi sc50
5. ladysman 262whp on 12.5 psi stock Z6
6. wilham320 d16y8 w/ greddy kit at 15psi - 252whp pump gas
7. turbozxi 250whp 250 TQ stock zc sohc IHIvf22 with around 15psi
8. Blind Fashion 236whp 189tq stock Z6 243000 miles!
9. TheShocker d16a6 231 WHP 206 TRQ t3/t4 60 trim .63 a/r 9 psi
10. beerbongskickass D16z6, 230whp
1999CivicEX
Revolver said:
Really?
D series:
Thanks
Sleeper
92 4doorSleeper
Revolver said:
Really?
D series:
lol, way to own
Shiznit
Revolver said:
Really?
D series:
what is that 10 out of 1million D series? thanks but i stand by what i said, that is of course unless you get your car tuned by jeff evans.
EDIT: also how many of those 10 cars are still running? just becaused they were dynoed at that hp & tq doesnt mean they lasted very long. for youre arguments sake i know #1 is still running strong.
Revolver
Oct 10th
Shiznit said:
what is that 10 out of 1million D series? thanks but i stand by what i said, that is of course unless you get your car tuned by jeff evans and spend 1g doing it
You said a stock D block can't handle more than 200whp, which obviously it can. Who cares if its 10 out of a million. Not everbody with a D turbocharges it and even less try for more than 200whp on the stock block. That still doesn't mean it can't handle that kind of power.
Shiznit
LOL okay you win dude
quicksilver1689
tuning owns you
With that combination i wouldnt go over 300whp because of the sleeves getting distorted under high pressure. Id say 10-13psi on a garret gt28 or gt30 would be good. PSi denpends on the CFM and efficency of the turbo.
anekin007
Unregistered User
boost around 12-14.. the gt28r turbo is a small turbo but has a fast spool.. spooling at about 2.5k rpm and full boost in another 1k rpm. boosting at 7 wont get u much..u ll be lucky to get 180-190 but it still depends on all the other parts u have. the turbo max out about 300. i got the same turbo in my room just sitting and waiting for all the other parts. when i get all the parts i'll boost about 10 psi on a stock block.
