seafoam question help asap
slod16
i put some seafoam through my intake in drove it around everything was going fine then got back shut off started rite back up then tried figering out y my plug wire is popped up so took the plug out in back in now wen i start its only running on hree cylyinder in i can hear the plug kind of tickin like it trying to spark is the seafoam or plug??
hardcore97
Hard Core
what do you mean you put it through the intake? did you use the brake booster line coming off the intake mani?
is the wire clicking down all the way on the plug?
slod16
yeah through the brake booster running from intake in i didnt do that much at all in yeah im pretty sure its on all the way its been popping up lately but now not working at all i just hope seafoam didnt cause this because it ran fine until i did that
Project "H"
Project "H" Racing
try the spark test,take that plug out ground it to something(valve cover) and see if it sparks
slod16
i think they are all sparking i put gloves in pulled each plug off while running in didnt sound diffrent in its idiling at 500-900 just the exhaust putters in when i rev it up
Project "H"
Project "H" Racing
yea wwhen i put the seafoam in mine it ran a little ruff for a few days so its normal
slod16
man im hoping im letting it idle out because i dont kno if youve ever cleaned your throttle body how it putters for a while thats kinda how it im hoping damn but then afgain it ran fine wen driving till the smoked stop
Project "H"
Project "H" Racing
yea ive done it and it smoked like crazy and ran ruff but it went away
slod16
yeah i dont kno it shouldnt be runnin this ruff forsure its deff only running on 3 cylinders the plug is good i dont kno what else to do really no cel are anything
Project "H"
Project "H" Racing
id give it a few days and if its still running ruff id check maybe the fuel injector for that cylinder
slod16
i dont think its anything but the plug or wire because it ran fine until i took it out in back in to make sure it was set in no oil on it...in my tach goes crazy
hardcore97
Hard Core
your tach goes crazy? check your grounds. mainly the one on the thermostat. make sure they are all getting a good connection. the tach wont just go crazy unless something electrical is causing the problem. sounds like my brothers hatch. did the same thing. the ground on the T-stat wasnt tightened down all the way.
slod16
yeah well not like bounces to redline but it will say 2500 rpm then jump to 4000 im hoping its the wire thats bad
31dev31
Chillin' Canadian Member
If it sounds like it's running on 3 cylinders and you just ran some seafoam in them. You probably have fouled the spark plug... try replacing the spark plugs and go from there.
slod16
yeah ive done that because i just replaced so i put the old 1 in to check it in plus it was running good after i put seafoam in until i took the plug out in back in
bizoneoeh
Ex-Gang Member
don't you know anyone in your area that can help you?
slod16
not on a sunday night at 10 pm im givin up tonite because almost positive its ignition back at it tmrw..
