if it wasn't temp, you spoke to no god.I had both and compared them visually and then asked a honda god and he said they were the same.
way before his time brotherif it wasn't temp, you spoke to no god.
factory specs allow for 28psi variance between cylindersyour compression numbers suck i think that is why it sounds like ass. a varriation of almost 20 is horid. 5 is ok but anything over that means pure ass. but your car does look good on the bright side.
gsr pistons. the gas that was in there was 87, i added octane booster which should have brought it to roughly 93. and then once that runs out, ill put in some 94 for a tankwhat gas do you use? adn what pistons are you using again?
The GSR has a dual runner intake plenum (so does the K20A3). A longer runner is used in lower RPM's to boost torque. AT higher RPM's it switches to a shorter intake runner to boost HP.someone told me that it opens up the butterflies at full throttle? or maybe at a certain rpm, or possibly a combination of the two?
i decided to pick up a blox manifold anyways, so i dont have to worry about it
that wouldnt make noise all the time though, would it? it sounds like its coming from the head. and its a tapping noise that varies with rpmi was gonna say i bet it is the gas you put in. so maybe go back and readjust your valves. could it be noise from something else, ie your clutch throw out bearing?
i have a thread over on Club Integra, took some pics along with my bros sweet ridepics of the whole car?
