Cojoe15
Hello,
Car: 1993 Honda Civic DX 1.5L Automatic Sedan
I have a problem with my shifter being stuck in park. Before you respond please read entire post.
In November of 2015 I had my ECU go out on me and I took it to the dealership to get replaced. This spring (2016) I bought new struts to replace on all four tires. Getting into that I nearly replaced all the suspension except the front lower control arms. Everything else suspension is brand new on my car. Before doing this work one day my shift lever wouldn't go into park so I just stuck a small pocket screw driver into the release lock. I thought it was the safety neutral switch so I replaced that while my car sat thinking that was the problem. While the car was parked for three months I worked on the suspension I never got to try the safety neutral switch. Got the suspension done and went to take it for an alignment and it was still stuck in park. I looked on here and a lot of people suggested the brake switch that controls your brake lights. I do have brake lights so I didn't think that was the problem. I did take the connector out and shorted the wires together. My brake lights came on but the shifter was still stuck in park. I got onto a Honda parts site and started looking at diagrams and seen that there is a shifter solenoid that releases the shift lock. Today I went to the local junk yard and got a shift solenoid off of a 1994 Honda Civic DX. Came home to try it out. While I had the cover off of the gear shifter I put the key in and right before the engine cranks over, during the same time you hear the fuel pump prime the shift solenoid primed or jumped a bit. Kind of like it tested itself. That was the old one. I put the one on from the junk yard and it did the same thing. I even started the car to see if that what it needed. Still the gear shifter is stuck in park. I found the 92-95 Honda Civic service manual and looked up the diagrams and wiring for the shifter. I found out that there is an interlock control unit next to the brake pedal. One of the yellow wires from the shift solenoid comes from that and the other comes from fuse 15 (10amp) and a fuse 42 that I couldn't find that should be under the hood next to the battery according to the service manual. I replaced fuse 15 for the heck of it and even went to the junk yard and got the interlock control unit. The junk yard interlock control unit did not do anything still the same problem. So far I've replaced or tested, safety neutral switch, shift solenoid, control interlock unit, fuse 15, brake light switch and I even check the connectors between all areas. It could be that one of the junk yard parts isn't working. I don't have a meter on me to check voltages. I just know that it isn't working. I'm attaching pictures of the the units that I'm talking about and even screen shots of the parts in the manual. I'm missing something. Could the brake light switch be my problem even though I shorted the wire out? This shouldn't be that difficult especially with the service manual pages. Please look over everything for me and give me some suggestions. I even looked at my bulbs and had one out on me. Replaced that bulb and still having this problem. Look at reply for other screenshots.
