Sickest Rides you've ever seen
vjf915
Always loved the Lotus Elise............
And edit for a beautiful color......
Laozy
hooked_on4
RegularFlush
sickness to come:
Blower
Miata
Jiz on yo face!
post finished pix in Septemberish when it's done
id even use the svt zetec in a rwd setup. theyre damn good motors too. one guy was testing his to see how much power it could make with everything stock except for the turbo, bigger injectors and an aftermarket ecu and he finally blew it after he had it at 750hp for about a week. and that was after a year on lower power levels, he had been previously at 550 the year before hand. ford has some nasty little 4 cylinder motors.
EMIIspecED
TEAM OCELOT rep.
my guess it was all the research that went into this
Engine
Longitudinally mounted, mid-ship, four-wheel drive.
Head/block aluminium alloy/aluminium alloy;
4 cylinders in line, Nikasil dry liners,
5 main bearings. Water cooled, electric fan.
Bore 86.0 millimetres (3.39 in),
stroke 77.6 millimetres (3.06 in),
capacity 1803 cc (110 CID).
Valve gear Dual Overhead Cams, 4 valves per cylinder, toothed belt camshaft drive,
Compression ratio 7.2:1. Bosch Motronic engine management system and fuel injection. Garrett T3 turbocharger/boost pressure 23 psi (160 kPa).
Max power 450 bhp (PS-DIN) (331 kW ISO) at 8,000 rpm.
Max torque 361 lbf·ft (489 N·m) at 5,500 rpm.
[edit]
hooked_on4
RegularFlush
repost but he was just featured in Speedhunters
I like this reminder
NYGraFFit1
I Tap JdmPrncss
That french car is Buhhttsheexxxytime lol all except for the rims
hooked_on4
RegularFlush
WTF is that roadster? Looks like a pissed off Coy Fish
EMIIspecED
TEAM OCELOT rep.
that's a veritas rs iii
specs:
Drivetrain
Configuration Front Engine/RWD
Engine: (edit ac: pretty sure its the bmw) V10
Displacement: 4999 cc
Horsepower: 507 bhp @ 7750 rpm
Torque: 384 lb-ft @ 6100 rpm
Max RPM: ---- rpm
Transmission: 6-Speed Manual/7-Speed SMG
could be repost but i dont care
[/IMG]
NYGraFFit1
I Tap JdmPrncss
I'll take all the open one's you take the ones with the sun roof still on ;) deal
hooked_on4
RegularFlush
i won't be greedy i'll take one and give my friends one too :D
