Sigh...
Drfunk1155
Okay let's get this over with.
Apline headunit connected to dual amp and subs
Installing ( trying to) subs. Two twelves.
They are bridged. To a single 560 amp.
RCA and remote are connected to headunit already.
4 guage is hooked up with fuse to new battery in trunk.
One sub turns on. But it barely hits at all.
I know they work fine( just unhooked them from brothers gsr)
same wires everything.
Ground wire is connected to non painted chassis bolt.
All wires are snug.
XeroReboot
Z6-All Motor
All wires are snug.
May sound stupid, but if your deck has seperate bass controls, are they properly set up and turned up?
lethal6
Your Mom's Moderator
Just a quick note of advise. You might get a better response if you title the thread correctly. Might help to put your question in the title instead of one word. A LOT of helpful people just overlook them when they aren't descriptive.
About your problem, I would make sure the wires are hooked inside the box. Might have come loose when moving it. I would also check the settings on both the amp and the deck to see if they are set up right. The settings on the deck might even be turned off.
