SiRyan-Vallejo, Ca (56K Turn around)
ReggieSD
PoPoy
very nice!
Melt
going to vallejo in about an hour ... fittin to pick up a cuddybang bumpyface johnson at parkway liquor then go to my doctors appointment at kaiser .... then top it all off by getting some cheap ass s**t at value center.
RaYrAy
very nice! thats one of the more extensively modified FG2's i've seen. Outstanding!
SiRyan.
In the box:
Out of the box:
Before:
OEM Dogbone:
Lost a couple screws:mad:
After:
SiRyan.
Here's a description:
Ingalls new "Stiffy" torque damper is a elastomer shock that mount via 7 gauge steel brackets between the engine and the chassis, reducing or eliminating power robbing movement improving off-the line acceleration for your vehicle. The "Stiffy" has hardened spherical rod ends, aerospace grade fasteners, 6061-T6 Aluminum body and an adjustment range of 6.75" to 7.2".
- Greatly improved off-the line acceleration.
- Reduced wheel hop.
- Improved vehicle stability.
- Reduced shock loads on driveline components.
- Smoother shifting.
- Reduced wear on exhaust system joints.
- Less vibration transmission to the driver compared to polyurethane dampers.
Declectic
SeanJohn1802
wow... a replacement torque damper, nice!!! Should work with the non-Si models I think since they appear to use the exact same mount
where'd you get it??
and when the hell u gettin these new rims? i'm hella curious
SiRyan.
I just payed the other half of the Works on sunday which means I should be getting them soon ( couple weeks, I hope). I got the Damper from Excellerate a vendor on 8thcivic.com for $135 from a group buy which they have have going on again.
