HAHAHA, i get that Turbo comment also, its too funny, but yeah, like everyone else said, thats normal if u've changed ur intake...
...Peace
...Peace
true said:its the CAI if the only time you hear it is when accelerating... perfectly normal.
EXSoon2BSi said:[Has anyone found this to be a problem on Short Ram intakes? When I had my short ram on I heard the noise when accelerating too. I can't tell you what it sounds like now b/c it's getting a facelift, so i haven't seen it in a few months.
WTF???SQL2112 said:Its on the back if the intake manifold..has a little black tube thing on it which I think is the electric motor. Its how the car sucks air in when your stopped/idle. The screw that open/closes the valve is on the throttle body right above the inlet where your CAI attaches.
Basically, if you have low/erratic idle the idle air control unit is usually the problem. Always check/replace PCV valve first though since thats only $2.00 and a new idle air control is like $150 at the lowest.
When the 6th gen civic idle is too low, usually, unless you played with the rubber stops, the hood will rattle very loud. Twist them in farther to make the noise go away then order a new IAC from Autozone or the dealer.
I know a lot of people hate Autozone but they use Linux so,I gotta support them.
yea i'm with you. WTF??RICDOGG said:WTF???
HAHHAHAHAA
