spark problem
marneli10
Hi guys i have a problem with my itr swap in my eg heres whats going on i changed my clutch line to a breaded clutch line but when i got the line it was a wrong banjo on it so it ended up sitting for about 3 weeks until i got the new one so i put the line on and started the car up it started good for about 30 min and it shut off didnt want to start back up so i started checking it it turns out my dizzy coil went out new one was 92 so i ended up getting the external msd one so now it starts up good but when in idle it seems like its miss firing im stuck on what it can be i need so ideas so i can get it fixed i have changed fuel filter and im going to change the spark plugs to see if it helps out i thought it was the wire that runs from the cap to the coil but when i changed it helped for a day and today it did it again any ideas plz help me out
Sammy D
My only suggestion would be to make sure you plugged all the spark plug wires into the right spots on the dizzy, because that would definitely cause a misfire.
Good luck, hope this helped!
marneli10
Just changed the spark plugs and still nothing yesterday when i was driveing back from work it was miss firen like crazy but it seems its only while im at a steady speed if i press the gas it doesnt do it any one else help out plz
. <--- In case you need that :smackself:
Is your CEL on?
