doh its prob a stock eclipse or near stock 4g63 meaning if its a 1g it came with a 14b , 2g a 13b or a t25
all tiny tarbos... hes prob jus got a aftermarket bov cuz hes the rice though the 2g one does suck... leaks at 12 ad is plastic
plus they arent geared as high as hondas are, so they do spool down low faster
also many factors will help spool faster besides nitrous which is dumb ... haha a larger dp will help ,free flowing exhaust, of course a bb turbo.. the list goes on
having a screen over the compressor intake instead of a filter will help spool much faster as well
i could drive normal to 4000 as long as i wasnt going sloww, if i gave it enough gas to move to 4k i would blow off everytime... you don have to be all out balls to the wall....
and Twin turbos arent so u can use 2 smaller turbos, they were made to lessen the effects of that blammmm boost hits you and your car goes nuts
so boost will be more progressive over the power band
though some set ups are sequntial, some are high boost low boost
a single turbo sized for your setup is all you need
a gsr built with a smaller t3/t04e 57 trim can easily push a crx into the 11s if built right
you could go bigger if you wanted to be king of the dyno but you are going to eat tires all day
you would prob onlyu need like 350whp... to get what you want
on a built gsr it ssimple
stock block u could do near 300 with a great tune and same turbo
