spray or boost for gsr swap??
Stock99ex
Willing to Learn
So i've been hearing some mixed things about some forced induction for a gsr swap. Ive been told that i can run up to 8psi on a t3/t4 or t25 turbo setup, but then ive heard i will only be able to run about 4psi. Then i was told i should just run a 50 or 75 wet shot. The people suggesting spray said they've been running it for years with nothing major happening. I would much rather run 8psi, but if im stuck at 4psi i just dont think it'd be worth it.
Thanks for reading and your responses.
mymmeryloss
RHD is where its at
U should really do some research instead of listening to your retard friends...
Sent from my Butthole using Fart power!
TokyoSkies
Boost Junkie
That was brutal lol...
But yeah. Boost + GSR = boom, unless you put quite a bit of money into it...
mymmeryloss
RHD is where its at
:what:
Stock99ex
Willing to Learn
HARSH! lol... Thats why i posted the thread, was to get people with experience. With the nitrous shot, the guy that suggested it had been running a 75 shot on his stock d16 for 2 years.
Tokyoskies, really, even with low boost. That sucks. How could i break 225 whp then? what would you suggest without going to crazy. haha
obracer12
mymmeryloss is 100% right, not harsh.
Don't listen to what people heard and are trying to pass off as fact. Read the sticky sections here.
To put it in perspective, and this is the key to Forced Induction, PSI is IRRELEVANT. aim for WHP goals, not psi goals, every compressor (turbo) psi rating is dependent on sizing... so with a T3/4 or a t25@ 4psi = different hp gains.
I have built several gsrs on stock internals in budget build situations that are around 10k miles @ 250 - 300 whp. it comes down to the quality of the parts, the tune and the driver not being a retard. reliable parts = a reliable build, a good tune adds the longevity, but none of it is cheap and easy.
Spray can be run the same way if you tune for it properly, the advantage to a turbo is.. you never run out.
Read, learn and stop listening to gum flappers that are "experts" unless they own, built and drive a turbo variation of the motor in question, their input is as good as horse s**t.
100% false
I daily a b16a turbo (almost the same compression ratio as a GSR) stock internals, and a GT225R making 250WHP / 185 ftlb
am close to 25k miles post build, not even a boost spike or A/F leaner than 13.8 to speak of.... it can be done reliably and last a long time if you do your homework and don't douche it up.
CJ89
No title needed :)
Cheap, Reliable, Powerful, you can only have two. :beer:
Sent from my DROIDX
Stock99ex
Willing to Learn
just to put things in perspective too, I drive just under 50k miles a year... I neeeed it to last. Im almost getting second thoughts. And just save for a wrx or sti that i really want.
