Stereo Install
1991civicb16
Guest
Ok so i got the stereo all wired up except for the ignition wire i cant find it i found that it is the yellow/red but it is not in my dash area looks like the previous owner really messed the wiring up. Does anyone know were else i can go to tap into the ignition wire? Also is there a dash kit for the ef civics? i was told to use the metal cage it comes with but the cage is not large enough there is space all around it.
leothelion
d:p
you can find the ignition wire from the security harness(green thing), check online for a pinout to find exactly which wire it is. but what happend to your old radio harness? it should have it in there. you can get a dash kit for an ef, look on ebay and stuff and you will find one.
1991civicb16
Guest
When i got the car there was no stereo in it. I have been going around to alot of places and the supposed 90 civic dash kits dont work they are double din kits and i got single.
1991civicb16
Guest
I figured it out i was missing the stock plastic piece behind the counsel got one from the wrecking yard and slides right in. sounds good too!
