Try a different auto parts chain store like O'Reilly.Autozone doesn't pull codes anymore ..
You definitely want to fix this^. You might scout junk yards for a replacement plug.Speedo works but I'm still getting a code, I think know what it could be . The plug from the wiring harness is starting to fall apart. When i Unplug it from the sensor the white clip in the plug gets stuck in the sensor and I will have to reconnect it to get the white clip out.
Clean the throttle body and adjust the throttle cable to have some slack (up to 1/2").I do have some idle problems. Upon start up my car will idle like normal, I let it warm up for a bit then drive .. when I come to a light or stoif sign my idle will remain high, I'd say around 1500-2000 rpm . If I tap the gas the idle will go down then back up. Most of the time it will do it on its own .. I've cleaned the IACV out , I let it dry and reinstalled. The car drove fine idled even better, so I go back home let the car sit then I go for another drive. The ran good for about one second, check engine light came on and my car began to jerk If I pressed on the gas. I would have to lightly press on it to get the car to go . I forgot to mention, I started my car let it warm up to normal temp . I pulled the connector on the IACV and my idle went down, the car didn't die nor acted like it wanted to cut off.. isn't it supposed to die ?
Haha...what do you mean it didn't work? What didn't work? Your posts often lack sufficient detail to assess the results. What did you actually do?Didn't work .. I tested the 2 wires going into the IACV sensor and got 1.66 that's with the meter set on 20v . I read its supposed to be at least 5v. This is with the key on and sensor unplugged .
I Cleaned the Throttle body and the throttle cable already had about a 1/2 inch of slack .. i turned the car on and removed the intake to make sure the plate inside stayed closed and it did ..Clean the throttle body and adjust the throttle cable to have some slack (up to 1/2").
This test couldn't yield much useful information because the IACV is ground controlled. Repeat the test only on the Yel/Blk wire using the engine as ground. You should read battery voltage.I unplugged the sensor, then I turned my car to the on position . Turned the multimeter to 20v stucked the black probe in one terninal and the red one in the other. I got a reading of 1.66v .
Please write unambiguously. Are you saying that P0505 is thrown?Tried to go to work this morning and the same code popped back up .. same jerking while driving in low gears, if i ease the throttle the car will drive fine it only acts up when i try to drive in 1st gear for a long time or give it gas. I have to shift quickly into second or the car with start jerking. . I am really stumped on this one..
Contrary to your comments in the two posts above, this^ indicates that you still have an intermittent high idle problem, right?the idle returned right back to how it was, high.
