Eh, no, not really. The headlights are fine (he essentially has CTR headlights now.. OEM!). I'm not a fan of the tails and hubs, but they don't ruin the car. And an intake is a f**king intake . Doesn't matter.I REALLY enjoyed seeing you clean and maintain pieces of the car most people do not. But then you ruined the headlights by painting the housings, tails, hubs, and put on that cheap intake.
Aw man, that really hurtsI REALLY enjoyed seeing you clean and maintain pieces of the car most people do not. But then you ruined the headlights by painting the housings, tails, hubs, and put on that cheap intake.
Replaced with what I hope, OEM. Not riced, OEM.Aw man, that really hurts
Luckily things like the tail lights and cheapo intake are just a little ways away from being completely replaced.
TokyoSkies, I've been reading up on the hondabond. Instructions to use it are, in fact, in my Haynes manual. Looks like it just takes a few dabs around the corners of the gasket. I'll write a more detailed post later this week hopefully.
they make the car look beat up and cheaper than a 15-17 year old econo-car really looks.Oh I've definitely learned my lesson, OEM almost all the way
Those hubcaps are here to stay though.
Interesting! I just did some research, and saw that Hondabond (or Permatex Ultra Grey, which is essentially the same stuff if you can't get Hondabond) is used to seal over the camshaft cover. Never knew that! Looks like I'll be picking some up.Aw man, that really hurts
OH! So you stayed in the same econo-box category!Puma, You know, I almost bought a Geo Metro...
TokyoSkies, Permatex Grey sounds promising, I might still spring for Hondabond with this though, just to be safe.
<3they are in fact the same, i think hondabond is black and the other is grey. the price is not much different. look i HELPED someone! this s*** is getting too real for me. sooooo uuuhhhh f*** YOU N000B YOUR CAR IS A RICER PIECE OF s***!!!!!!!!!!!!!!!!!!!!!!!!!1 GET OFF CLUBCIVIC.... phew now i feel more comfy.
STOCK, UNMOLESTED hubs help a car better than shiny steel wheels. Stock dark wheels make it a 'lesser than less' base model, and show more imperfections.Damn, I either need to get off the internet or go back to uncovered steelies
:-\ So much for this page of my thread.
Oh BTW, it turns out I didn't need an UNMOLESTED P28. We now have no f*cking clue what is wrong with the pile of sh*t, b/c it ran like dirt on 3 different ECU's yesterday. Gonna burn that thing soon...STAP saying unmolested!!!
The distributor is pretty straight-forward. I remove mine pretty regularly. There's a line on the shaft of the distributor that aligns with your cam. It can literally only go in one way. You really can't screw it up. If it doesn't slide right in, rotate the shaft on the distributor 180 degrees, and slide it in. Do NOT force it in. It should slide in with very little resistance, and it should "click" once seated right. Basically, ensure it's lined up with the cam. Once you get it off, and look at both the dizzy and cam angle, you'll understand it right off the bat. Once it's back into the head, thread the bolts into the dizzy finger tight (leaving wiggle room). Start the car, and rotate the dizzy clockwise/counter clockwise to ensure timing is correct (car's idle will fluctuate. It should idle at 500-600RPM warm). Once you've got the idle right, crank the bolts down to spec (I think they were something like 7lb/ft, check your Hayne's manual), and you're done. It's cake.As I left work today I took the time to really look at my car.
I'm totally happy with it and love to drive. Sorry to disappoint.
Alrighty, time for astro-physics
Job: replace the (supposedly) leaking valve cover gasket.
I'm going to be replacing:
- Valve cover gasket
- Distributor gasket
- Distributor cap(?)
- Spark plugs
- Spark plug wires(?)
- Oil (engine oil change)
- Oil pan gasket (I'm not sure)
- Timing belt (I wish)
Parts list:
- Hondabond / Permatex ultra grey
- Spark plugs
- Spark plug wires
- Oil pan gasket + RTV sealant
After reading through the service manual and online, I get that there's an opening behind the distributor where oil can leak from. Now I really don't know which seal is leaking, so I'm set on replacing both.
Picture of connection between dizzy and engine:
For the distributor, my manual says that I have to turn the engine over until it's pointing at the connection for the first cylinder. On forums I've read that I can just mark the location and not worry about it. What's the chances of taking the dizzy off and not getting it to match up and go back on?
I've seen spark plugs at Walmart that have four electrodes, quite unlike the ones currently in my car. Any input on what type of spark plugs to get?
For that matter what about spark plug wires? Are those one of the OEM or nothing items?
I'd like to go ahead and remove the oil pan and clean it, I image the interior hasn't seen the light of day since it was put on the car. Thoughts?
