The NA SOHC -- Upgrades
Martin Racing Design
FKA Carbon Creations
Taken from Honda-Tech.com. Enjoy. And dont be a f**king queer and start talking s**t on my post. Ill kick you in the face. Fair warning, and enjoy!
DISCLAIMER: Some of these modifications are not cheap. For all of you who have to b***h about the cost of some of these items, I have this to say. Fast, Cheap, Reliable…pick two.
I want to provide some information as to why I am backing the Single Overhead Cam (SOHC). Almost every Civic out there has or had one to begin with, and for the price of a swap you can put a turbo on there that will easily out perform a DOHC (Dual Overhead Cam) for the same price. Another thing for you weight junkies, the D series engines weight in at about 75lbs less than a B series.
Intake: First things first. Allow the engine to breath; after all, engines are nothing but big air pumps. To start off, we look at the filter and piping. Cold Air Intakes (CAI) are nice, and can be found for under 50 dollars. The great thing about the CAI is that they don’t suck in hot air from the engine bay because they are mounted in the fender well. K20’s (RSX-S for this example) have been dynometer (dyno for short) proven at +20 whp (wheel horsepower) with a CAI as apposed to the 5-8 whp with a “short ram” design. There have been dyno sheets that show a 3" piping makes great power (more air flow), the Integra Type R (ITR) CAI will fit on Civics and is unlike the EX/SI CAI, which is 2.5”.
Following the air flow we come to the throttle body. This is more of a throttle response upgrade than a horsepower upgrade. UNLESS the stock throttle body is too small to allow all the air the piston chambers can pull in at wide open throttle (WOT). Basically, adding a larger throttle body allows you to be a “full throttle” faster because of the larger volume of air. Any throttle body for a H series B series or D series are interchangeable, with one catch, you need to pay attention to where your IACV (idle air control valve) is. For example, the D16Y8 (96-00 EX) has different mounting points. On the automatic, the IACV is mounted on the throttle body and the manual has the IACV mounted on the back of the intake manifold.
The VTEC B series and B20 (CRV) throttle bodies are all 60mm in size. Except for the ITR, which is 62mm. The H22 is also a 60mm throttle body, while the Civic gets a puny 56mm. Make sure when you add the larger throttle body that you port match (make the holes the same size) the opening of the intake manifold.
Next in line is the intake manifold. You want the D16Y8, often referred to as the Type R manifold for the D series. It has short, fat runners and a large chamber to allow the air to distribute to each cylinder properly.
Also, for the NON-VTEC guys out there, you can go from this:
to this
it has the common horizontal throttle body, which will allow you to use the larger CAI's. Here is a link with a complete how-to:
http://www.makuragi.s5.com/civic_99/Y8maniswap/
NOTE: This will not work for the D17's. Honda had the bright idea to make it a return-less fuel system.
Lastly, don’t forget that heat here is a performance killer. You can invest in a Hondata intake manifold gasket. It is designed (and proven) to protect the intake manifold heat soak. I have removed and replaced my throttle body coolant lines, they don’t make enough of a difference.
Exhaust:
Lets start off with the exhaust manifold (header). There is no OEM exhaust manifold out there that doesn't need work. But, for those of you who want to stay naturally aspirated (or don't have the money for a turbo) a used aftermarket manifold for the EX is where you want to go. There are a lot of people out there who by the time they can swap have already put a header on there D series and now need to sell it. You will have to relocate your catalytic converter under the car to use this header configuration (which happens to be illegal in some states). There are two different designs for a header. The 4-2-1 (or Tri-Y) and the 4-1. It is said that the 4-1 costs you low-end torque to give you more power up top. However, if you follow this link http://www.automotiveperformanceengineering.com/header.html you will see that some 4-1's have better low and mid then the 4-2-1's. Header designs are so good that this is more a preference thing IMO. One advantage of the 4-2-1's is that you can remove the lower half when you need to pull the oil pan, instead of pulling the entire header. The HF (all Civics other than the EX and SI) exhaust manifold can be modified to add a turbo. Then you don’t need to spend the extra money on a turbo manifold. See homemadeturbo for more information.
Following the exhaust stream out, we come to the Catalytic converter. Unless yours is old, don't worry about it. For those of you who can afford to upgrade the cat, tests have shown that a 3" free flowing cat has almost flown as much air as a 3" test pipe. In fact some people were shocked at how well a free flowing cat works (and it's legal). Or go with the $10.00 test pipe from Home Depot (NOTE: Test pipes are not smog legal and you face a $3,000 fine). That's right, people have even made there own test pipes with minimal effort.
After the catalytic converter, it’s the “Cat-back”. Most people recommend using a 2.25" sized exhaust for the little 1.6L. And a lot of the aftermarket exhausts are 60mm
or 2.3 inches. I agree that they should be at least 60mm. But, you also want to make sure you get mandrel bent piping and straight through designs on both the resonator (if you have one) and the muffler. If you don't get the straight through designs, you will loose power, it's that simple. However, with straight through designs also comes noise. A good compromise has is an exhaust that comes with a silencer. You can remove them for “track days” and leave them in for daily driving.
Transmission/Flywheel/Clutch: Remember this, the shorter the gears the better. It is easier for the engine to push/pull the car. MistaBone's link: MistaBone's trannies The VTEC engines have always had the shortest gears and it is a “bolt on” part. The 96-00 transmissions will bolt on a 92-95 Civic. One small thing to consider is that the 96-00 transmissions have steel shifter forks instead of the aluminum forks that are in the 92-95 transmissions. For you cable transmission guys, there are the Hasport kits that convert your Cable to Hydro. And, SSR offers a 4.7 and 4.9 Final drive for the D series Hydro transmissions. HX/VX/CX owners, upgrading the transmission should be the first thing you do, this is a HUGE difference. Once you get the shorter geared transmission or already have one, a limited slip differential is the second biggest thing to have on a D series. The performance improvement is profound. I recommend Quaife because it has gears, not a clutch and it comes with an unlimited lifetime warranty.
A lighter flywheel is also a recommendation. Not only do they increase throttle response, they “free up” horsepower by decreasing rotational mass. (Just like the whole argument of reducing wheel weight) The aftermarket offers weights varying from 8.5 to 15 lbs. You can shave your existing flywheel to no less than 13 lbs. However, this is a controversial issue and if you search will discover how everyone feels about it and the dangers that can come with it. The clutch, talk about a weak POS, the stock clutch simply sucks. With even stock tires your clutch will start to give out while doing a warm up burn out at the strip. There is no doubt, you have to upgrade this part or suffer the sliding shift every time you drive hard.
Engine: Well, where the hell do we start? The motor mounts all have gaps in them. jimfab.com has inexpensive polyurethane mounts. And the mounts that they don’t make you can go to hasport.com and get the rest. Okay, now that you got that sucker still, lets increase some power. On a naturally aspirated engine there are # things you can do. 1. Up the compression. 2. Increase the displacement by bore (size of pistons) or stroke (crank). 3. Add more aggressive cams, or cam for the SOHC. One way to up the compression is to mill the head. It is very important for you to not remove more than .30. If you do, you risk timing issues because the timing belt is going to have slack and you will risk jumping teeth on either the cam gear or the crank and your timing will get screwed up. You can also get thinner head gaskets, the Y8 is cheap and is the thinnest metal OEM head gasket that you can get. Now that we have covered some inexpensive increases, lets go to pistons. The 1988-1989 D16A1 Engine came with some really high dome pistons, they will increase your compression ratio as follows:
d16a1 pistons (stock bore) in the following with a y8/z6 metal head gasket (no mill):
d16a6= 11.0: 1 compression
d16z6= 12.0: 1 compression
d16y8= 12.6: 1 compression
D series Compression Calculator "use the a1 piston to deck height of .040"
Obviously high compression and you 91 octane folks should consider a thicker head gasket. However, 12.5:1 can be driven daily on 92 octane. Since you have decided to open that sucker and upgrade the pistons you should also consider upgrading your rods. Whether you decide to shot-peen your stock rods or upgrade to some LS rods, it’s up to you.
LS on the left, D16 on the right.
Better yet, shot-peen the LS rods! When upgrading these, you should consider some ACL bearings and ARP rod bolts. Strength is always a comfort, right?
The head is what traps all of the power in any engine. Be it naturally aspirated (N/A), nitrous injected, supercharged, turbocharged or all three. It has the valves that allow the air in and out of the combustion chamber and the cam that opens and closes the valves. Porting is the process of removing material to make the holes for the valves larger to allow more air even if you use the stock cam. But, within the head you have all of these moving parts that rub against each other, even with oil there is friction. To reduce friction, you can get bronze valve guides, coated valves, and roller rockers. Roller rockers are cam followers that have wheels instead of a contact point. They greatly reduce friction and, the D16Y5 (HX) has them!
Unfortunately, it only has a 2-lobe cam instead of a 3-lobe cam. Again another crazy topic that has been discussed a few times. Still with a custom cam, This “VTEC-E” head could theoretically produce more power than the VTEC head ever could. Since the rollers would allow for a cam lobe so aggressive that the regular followers would fail. Adjusting the cam with a cam gear can also change your power band to what best suits your driving, some drive easy, some drive hard every now and then, and some visit 7200 with every stop light and every shift. Well, almost. Remember, an engine is an air pump, the more air it moves the stronger it is. And the best way to move air is to open the valves really high (lift) for a long time (duration). A good quality camshaft maker is Crower, my personal choice. There is also, Zex (comp cams), Crane, and Skunk2. Some companies that make regrinds are Hondasaver and Gude. I personally don’t like regrinds. They were stock cams that had material added then “reground” off.
Cooling: Hey, if you don’t know this, heat kills. Keeping your engine cool is not just the radiators job though. The water pump, thermostat, your coolant/water mix, and even the radiator cap affect your ability to cool the engine. If you change one you affect the whole system. Radiator caps pressurize the coolant to raise the boiling point (good) but, if you over-pressurize, the radiator could fail because of the plastic tanks on the sides.
There are two radiators that you can use for the Civic; there is the Del Sol, which is a dual core. Or it has two cooling cores, one in front of the other. And the other is the Integra. You have to make custom mounts but you will have your needed cooling for sure. Or, spend stupid amounts of money ($400) on an aftermarket radiator that is a very efficient aluminum kind.
For you track guys, since antifreeze isn't allowed, there is a product called water wetter. You mix this and water, no coolant. DON'T use this on the street. Antifreeze does exactly that, when water freezes, it expands and will crack your block, radiator and head. You've been warned.
Fuel/Spark/ECU: Fuel isn’t as easy as we all would wish; a fuel pressure regulator (FPR) isn’t necessarily a good thing. Too much fuel can cost power, and forcing your injectors to flow more than what they were made for can hurt them as well. I personally believe that you should upgrade the system as a whole, injectors, fuel pump and regulator. And same with the DOHC ECU’s, they can feed more fuel than needed as well. The best way to figure the needed fuel out is to “tune” on a dyno that also has the capability of reading your air to fuel ratio. Whether it be with a FPR or a fuel controller. Apexi makes a VAFC or VTEC Air Fuel Controller. Which allows you to adjust your fuel amounts in the RPM range. These are good but there is something better, Hondata. That's right, Honda is in Hondata, and they are making great amounts of power on the SOHC’s. Supplying fuel is just one part though. You have to ignite it. To do this, NGK spark plugs, why because Honda sends their cars to the dealer with these inside. And then MSD, with only an intake or exhaust these will only add a little power however; they will get a cleaner burn and better gas mileage. With more air and fuel comes the need for a more powerful spark to burn the extra fuel. MSD has many different models out there to control the spark and increase it's strength.
The stock Civic (other than 99-00SI) and Integra LS fuel pumps only flow 79lph and the SI, GSR, Type R flow 135lph.
Well, that just about sums it up for now; feel free to add any knowledge.
Don't waste your money on a B16!! It's still a torque less 1.6L engine. If you truly want to swap an engine save for a B18C1 or K20, you’ve saved this much already save a little longer.
ImportRacerFF
Hey,
I'm rebuliding my D16Y8 as well. While im no where near as far as you (due to floridas low paying jobs) I just wanted to add in something you forgot to mention and a few opinions for the d16y8. *This is all opinion and is more then open to discussion*
Valve springs, retainers, seats ect. With any SOHC the real power comes from the head. While new valve springs won't give you better Horsepower, it will allow you to (a) increase the rev's if you wish (b) feel alot safer when driving hard. Just a little while ago one of my valves floated causing me to have a heart attack. While in the end all i needed was to adjust the valve, I decided it was time to start investing in the head. Crower, Skunk2, and Ferrea all make springs and retainers for the d16y8. While im not a fan of Skunk2 their springs look to be pretty strong. I would recommend the crower or Ferrea if you plan to go turbo.
The valves in the d16y8 are extremely good especially for stock valves. If you want to upgrade go with some stainless steel, but the stock size is more then efficent.
I haven't botherd with a Port and Polish yet on the head, mainly because im worried about the speed of the air (velocity) entering the engine. To big of a hole will cause the velocity to go down causing you a lost of h/p. I have not gone and looked at Port and polish vs stock yet if anyone has any dyno numbers feel more then free to add them.
As far as aftermarket headers go there are plenty of options out there. If you want to go with a descent 4-2-1 get the comptech header. Its discontinued so they are cheaper now. The DC Sports are pretty much based off (or visa versa) the comptech, therfore they are close to the same header. The APEX'I 4-2-1 is what i just orderd for my baby. I will hopefully (if time permits) post some how to's w/ pictures on the installation and then a review (after i brake it some =) If your looking for a 4-1 and don't mind looking extremely different look at the bisimoto header. Bisimoto if you haven't heard of him built the fastest SOHC civic. The header (looking something coming out of "aliens" ) uses equal length primaries to increase H/P. Very cool tech.
Some Don't's :
Vtec controller's on the d16y8 (as long as your running a computer w/ vtec already) is close to useless. The vtec kicks in right where it should. If you change the vtec engagment more then 200 rpms you begin decressing the effiecency of the engine. (unless a custom job is in order on the cams and timing)
Run your oil low. While this seem like a stupid thing to say, it is almost a weekly thing i hear someone with a civic saying that their engine light came on and vtec shut off. For some reason civics burn oil pretty quickly when they are touched w/ performance parts. Just keep an eye on the oil on a weekly basis, if the check oil light comes on during a turn you've burnt (or lost) the oil to the point where it can barely cover the oil pan.
As CarbonCreations mentioned the stock clutch is pretty crappy. While it can take a beating without going, it can't hold up on its own. You can beat it all you want, but even a fresh stock clutch won't be able to engage anywhere near as needed. It more or less slips in rather then engages on contact. Don't use a stock clutch if you plan on running hard and/or boost.
(Info and help from: www.9krpm.com and www.velocitytrends.com)
Very good addition =)
With my civic I was burning about a quart of oil a week :( Then again I hadn't messed around with the transmission before I crashed, so I was bouncing off of the rev limiter. Fun stuff when you're running 4-1's, a CAI, and a test pipe -- nice and loud and it sure as hell doesn't sound like a bumble bee zooming around.
My advice for the D16 is to build the rods/pistons and headgasket, get new cams and go cheap on i/h/e. Then when the funds are present, start upgrading for a turbo.
FMU and new injectors are a great place to start, especially if you have a VAFC. While you may (or may not, as I haven't researched this) be running rich for a month or two, you will definitely see more performance gains. It will also get you that much more experience driving a fast car, because the turbo setup you will get will be top notch. You would just have to sleeve the block to be able to support a good 2 bars of boost.
And lastly as ImportRacerFF said, DO NOT BUY A VTEC controller. It's as pointless as buying a chip for a stock civic. I mean, the engineers at Honda got paid to determine when it was appropriate to have VTEC engage and I doubt a common person would know more than they do.
Mr. Lin
Admiral Ackbar
How long did it take you to write that stuff up or was it a copy and paste because that's some good stuff, especially for a D16 owner such as myself. One question tho, about the pistons. Are you suggesting that if you take D16A1 pistons and throw them in a D16 block, your comp ratio will raise to 12.0:1? If so, that's a massive jump that'd do some serious damage, no?
Youll just need to run 93 octane. I don't know how you test what octane you need for compression, but from the information Ive read, people with 13 compression can run on 93.. *shrug* Ill look into it.
Mr. Lin
Admiral Ackbar
Was I at least reading you right?
Handlebars
None Taken.
that was, or at least part of it cut and pasted, i know for a fact ive read that elsewhere. but good post.
Handlebars
None Taken.
and 13:1 compression aint streetable in the least without some tuning. and its pretty worthless without the p&p head and a new cam, but then the problem with those pistons is they dont have large enough valve reliefs to run a larger cam.
Yup both of my "new" informative posts are from the net.
Handlebars
None Taken.
fyi, next time please give credit where credit is due. just say who wrote it and where it came from.
Sound Streamin'
Boost or Die
Originally posted by CarbonCreations Don't waste your money on a B16!! It's still a torque less 1.6L engine. If you truly want to swap an engine save for a B18C1 or K20, you’ve saved this much already save a little longer. [/B]
You said it!!! :thumbs up
Kamikaze
Sesquipedalian
another great write up!
One thing for the track peeps to note about using water wetter is to be sure and check with the track, some do not allow it or any other additive.
At about $25/gallon, it's not something you want to put in, only to learn you've got to dump it when you get to the track. Believe me, I know. ;)
Jas0n
What's up dogz!!!
nice wire up dude!!!! since I have a D15B7, I'll try to do my best to it!!!!!!
95civichatchcx
nice..i was wantin to do a swap since im gettin a job soon but which engine in the d series would u recomend for dragin in a 95 cx hatch?
d16y8 with turbo
or b18c1 with turbo
depending on your cash situation. the b18c1 is going to run your pockets REAL deep. IMHO T-SOHC will put down enough HP for most people, and you can build the block (pistons/rods/sleeves) for less than you can pickup a HMO b18c1.
AZSprmnn
From AK to AZ to AK to OR
damn im gonna have to print some of this s**t off
civic95
WOW:shock: awesome write up man. I'm deffintily gonna print that out for later use.
boricuacvc
El Gistro Mami!
i gotta read this since i wanna work my SOHC. thanx for the post
big_dan
the hippy tuner
you said somethin about gettin a cai for $60, all the ones ive seen online have been upwards of $140-160 (i looked at the aem v1 and the k&n cold air) what web sites have good cai for cheap
and btw this should be a sticky
