true.. but the thread is trying to help stop the same questions from being asked..i think the various reply's are good but when it all comes down to it. it is in the eye of the beholder. each person wants his/or her own personality in it. come on now how many nice lookin rides have we all seen , but pop the hood and what is that a motor from a yugo. some just want the look with a little buz in the exhaust. but at the end of the day it is the owners pride that counts...
I just bought a 1995 Civic Coupe with the D16Z6 and it has all the mods that's described in that article already. So what's next besides a turbo, a new cam profile? Cause my friend has the same car and engine, but without the header, exhuast and intake and his isn't nearly as snappy as mine, granted the car only has 125hp stock, but still. If those numbers are accurate, then I'm sitting on around 135-140HP with just a few mods i didn't have to pay for. I had my 1989 MR2-Supercharged stolen, which is why i bought the Civic and man I miss that quick punch and snappiness and it only had 145hp at the wheel, but did have another 20ft lbs of torque. The cars weight only around 200lbs different, so I'm looking for the same kind of snap that used to put my passenger's head in the seat without having to drop $1,500 for a turbo. Anyone have some ideas?Yea that makes no sense in 1500 on some bolts to get an extra 10-15 ponies. I only spent 200 on bolt on's and pretty much got the same specs. Saving money for an better motor and boosting is where you can find the bigger numbers.
the numbers in the article are correct, your car with intake, header, and exhaust should be laying down 110-118 whp. That 125 you're referring to is flywheel horsepower. You're not going to easily mimic the power of your mr2 because:I just bought a 1995 Civic Coupe with the D16Z6 and it has all the mods that's described in that article already. So what's next besides a turbo, a new cam profile? Cause my friend has the same car and engine, but without the header, exhuast and intake and his isn't nearly as snappy as mine, granted the car only has 125hp stock, but still. If those numbers are accurate, then I'm sitting on around 135-140HP with just a few mods i didn't have to pay for. I had my 1989 MR2-Supercharged stolen, which is why i bought the Civic and man I miss that quick punch and snappiness and it only had 145hp at the wheel, but did have another 20ft lbs of torque. The cars weight only around 200lbs different, so I'm looking for the same kind of snap that used to put my passenger's head in the seat without having to drop $1,500 for a turbo. Anyone have some ideas?
Yeah, I'm thinking of just dropping in a B18 cause this single cam, gutless Z6 is just pissing me off. I don't want a B16, cause I hear they're pretty gutless too unless you're riding around redline all the time. Although I hear the Z6 does turbo quite well...the numbers in the article are correct, your car with intake, header, and exhaust should be laying down 110-118 whp. That 125 you're referring to is flywheel horsepower. You're not going to easily mimic the power of your mr2 because:
1) your single cam isnt boosted
2) you;re front wheel drive now, not rear
3) torqueless
in a D-series? lol Our honda's make thier peak torque high in the rpm range as well, not down low.I have looked into an NA Dseries setup for a while now and yes the boltons help but thoes 3 boltons are way to expencive, cheeper options are out there and will perform just as good if not better, your paying for a name.
ebay cai
dc sport header
2.5" mandural bend muflershop exhaust job will cost you what? 1/4 if that of the msrp cost of that catback?
You want to make power NA, up the compression to the 11:1, 12:1 range, Eather high comp pistons or mill the head.
Get a stage 2 or higher cam and a adjustable camgear, Most cams will work with the stock valvetrain, many just require better springs, get some new stock keepers and retainers.
Larger injectors and a tune, couple this with a noname brand CAI/SRI and a cheap quality header and you got yourself a potent pumpgas NA Dseries.
You want to get even more out of it? get a aftermarket IM or ITBs or a carbsetup, Larger TB, bisi header(baller status), the list is endless with what you can do but it comes down to compression, cams and a tune for an NA D, figure out what comp you want, what cam you want and then do you want to mill the head or do you want high comp pistons?
But then again 90% of honda owners are dragracers so stick to your turbo, I will like to keep my low end power and torque for comming out of that righthand corner.
Not true, Cam, Cam Gear, Clutch, Flywheel, pullies, short shifter and intake manifold is all going to run me about $800-850. The only turbo kit i'm going to get for that price is a cheesy Ebay one and I'd STILL have to fork over even more for either install or a proper tune IF that kit didn't totally suck ballz.in a D-series? lol Our honda's make thier peak torque high in the rpm range as well, not down low.
by the time you buy a cam, valvetrain, cam gear, injectors, and high comp pistons you could have had a ridiculous turbo setup. Gotta keep in mind that there are small quick spooling turbos as well for a track car
Thats a few dollars less than I spent on my turbo kit and I dont think im at 118whp haahah.Oh my god! A whole 8 whopping horsepower for $1200! I think I'm going to jizz my pants!
I'd rather spend that on a turbo kit and gain 6x+ that.
Mines working fine. And if you want the most power out of the cam cam gear, flywheel etc, youre still gunna need a tune.Not true, Cam, Cam Gear, Clutch, Flywheel, pullies, short shifter and intake manifold is all going to run me about $800-850. The only turbo kit i'm going to get for that price is a cheesy Ebay one and I'd STILL have to fork over even more for either install or a proper tune IF that kit didn't totally suck ballz.
well considering you left out the valvetrain, injectors, and high compression pistons you've left out a big chunk of the power and cut the costs down to once again hardly gain anything.Not true, Cam, Cam Gear, Clutch, Flywheel, pullies, short shifter and intake manifold is all going to run me about $800-850. The only turbo kit i'm going to get for that price is a cheesy Ebay one and I'd STILL have to fork over even more for either install or a proper tune IF that kit didn't totally suck ballz.
