Update. I managed to get my hands on the correct steering knuckle. I actually did a straight trade with a guy for mines. Also found a type s coolant housing so I could utilize the new thermostat. Once that was done the lower hose had to just be cut to fit and I was good to go. Shifter cables are ran, ride height has been adjusted and still needs some more adjusting in the front. The rear is currently lower than the front. Might be time for a new set of coilovers. But anyway conversion harness is all set, heater hoses are all ran, suspension is all bolted up. Fluids are in the motor and trans and I did a test start and she actually fired up just a bit and then I shut it off until I can get the tuner over to load the correct base map for engine break in. Hopefully I take it for the first drive later tonight.
Bracket for the FPR came in. Gotta love those K-Tuned goodies that makes installs quick and easy.
I've had my friend who's shop I'm working in's personal EG hatch as a loaner for a few days now.
New knuckle for the manual rack.
When your all alone you improvise lol
Throwing the new thermostat on.
Back in business
Looks so different with the k in the engine bay.
Back in business
