Hey guys I have a 99 civic ex coupe 5 speed and I put it on the ramps today and I checked the underside and I saw the bottom wet with some liquid which I don't know what it could be maybe a tranny leak? Any ideas?
1) Buy Honda axle seals (driver and passenger seals are different) and Honda MTF.1st post. lol, but anyways seen something about axle seals. Does any one have a how to, on replacing? (98dx) Thanks!
Is the MTF in the transmission or the oil in the engine low?
Leaking fluid is pulled downward by gravity. Carefully inspect the engine and transmission surfaces to locate/trace the highest point on the transmission or engine where you find oil. Post pictures.
FYI -- MTF leaks most commonly come from the axle seals. Engine oil leaks commonly come from the oil pan, distributor, valve cover, or VTEC solenoid.
MTF is not reddish in color. Remove the MTF fill bolt and stick your finger in the hole to feel whether it is low.How do I check the MTF and the oil level is fine hasn't dropped since I bought it so it can't be an oil leak. Besides the color of the fluid is reddish. Ill post more pics of the leak.
It could also be the distributor o-ring. I've replaced mine. There are plenty of gaskets that are known to have to be replaced at times. Which one it is can vary car to car. My oil pan gasket was solid as a rock at ~219k miles.Well my dad gets back from Houston tomorrow and ill update you guys on the vtec solenoid or the oil pan gasket, or valve cover gasket.
