mechanically its simple, unbolt the transmission, drop it, and boom there is your clutch. You'll encounter so many lil b***h problms though so they bug the hell out of you. When you first start, you car has to be on the ground so you can crack the nut on your half shafts, take wheels off, use a wishbone and undo your brake assembly so it will swing out so you can pull out your half shafts completly, then unbolt the transmission, take off the starter, undo your engine mounts, drop that b***h, put on new clutch, i think you needed 12 pt rachets for that if i'mm correct, then redo my expert steps backwards...mechanically simple yes, the aggrivation of it...priceless
